Old 03-11-2013, 11:39 PM   #1
Yarflana
Drives: 2008 Base Model
When should PCV be changed?
Just that? What are the indicators? If the PCV connection or itself isn't working right, what are the signs? Check engine light? Hissing sound? Rough idle when in stopped with break on in drive?
Thanks for any thoughts.
Pat
Yarflana is offline   Reply With Quote
Old 03-12-2013, 07:01 PM   #2
Yarflana
Thoughts?
Old 03-12-2013, 07:31 PM   #3
hw6515
Drives: 08 Yaris AT, 350Z GT MT
I replaced the one in the car as a part of the 80k miles maintenance I'm doing.
It's so cheap I can't think of why didnt do it at 50k.
hw6515 is offline   Reply With Quote
Old 03-12-2013, 07:32 PM   #4
Yarflana
Ok...but why? I am curious to know what happens when it stops doing what it was designed to do...which I am not sure of either.
Old 03-12-2013, 08:01 PM   #5
cdilmore
Drives: 2010
You can easily test it. Just remove it, and give it a shake. If it doesn't rattle, it's gunked up - replace it. They are inexpensive locally or on the 'nets. You'll swear your car will run smoother and you'll have better luck with traffic lights.
Keep us posted!
cdilmore is offline   Reply With Quote
Old 03-12-2013, 11:27 PM   #6
Yarflana
@cdilmore - thanks so much!
By chance do you know the ft/lb torque spec on the PCV for when I replace it?
Old 03-13-2013, 12:56 AM   #7
clarenceie
Drives: Yaris Sedan
According to the manual, 20 ft lbs
I would like to also add, 117k miles and the PCV wasn't gunked up at all! :)
clarenceie is offline   Reply With Quote
Old 03-17-2013, 11:40 AM   #8
cdilmore
Drives: 2010
@Yarflana,
Were you successful in changing the PCV valve?
I'm sensing that Congrats are in order!
Old 03-17-2013, 02:09 PM   #9
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
Blow seals in the engine, make the oil filthy in no time. Maybe some other things, I cant think of right now.
UberSilver is offline   Reply With Quote
Old 03-18-2013, 01:27 AM   #10
Yarflana
Thanks but not yet...hit a snag with the brake line yesterday so didn't get to it...perhaps next weekend...thanks for the encouragement...I think it will be in good shape.
Originally Posted by cdilmore View Post
@Yarflana,
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 10:07 PM
PCV Valve Replacement devinlamothe DIY / Maintenance / Service 27 03-17-2013 12:06 AM
So when DOES the transmission fluid need to be changed dutchy999 DIY / Maintenance / Service 12 09-06-2011 06:18 PM
changed belt,got scan code POO1O yaris9876 DIY / Maintenance / Service 10 12-17-2009 11:31 PM
Has anybody Changed the Odometer in the HB pp.sweet DIY / Maintenance / Service 2 08-21-2007 07:00 AM
