Old 03-17-2013, 05:36 PM   #19
mr_miles
Drives: 2013 Yaris
Oh crap, I thought the stock seat rails were welded to the seats! Looks like I've got a project to do....
Old 03-17-2013, 06:48 PM   #20
vten
thanks butcher,
yup, mine comes with the wedge engineering brackets with the adjustable heights.
if they don't sale, itll ended up on my new ride or office :P
Old 03-17-2013, 07:27 PM   #21
Crazy Butcher
Drives: Yaris 2008
@Mr Miles No they are not welded they are held on by some torx bolt, let me see if i can snap some pics to show what im talking about.
Well After further investigation, Theres a part thats welded or something and cannot be removed
So the part that is welded is in the yellow circle. it goes from one side to the other on the driver side seat.
You need to remove the torx bolt in the red circles to get the L bracket off,on the other side i left the L bracket on but just removed the bolts that we're in the Bright green circles
Heres a view of the driver side seat L bracket, this one as stated higher is not removable
Here's the passenger side, the L bracket is removable on this side, but where the torx bolt are, is not.
Another view from under the passenger side
So after a while of figuring out where the screws are and plastic clips on the trim panels heres the result
Hope it helps, ill get the size of the torx male socket i used to get the bolts out.The male socket size is a T40.
Crazy Butcher is offline   Reply With Quote
Old 03-18-2013, 11:55 PM   #22
banifesto
Drives: Yaris Sedan
After swapping the seats, will the seatbelt & sensor work? looks like there is a wiring loom under the stock seat.
banifesto is offline   Reply With Quote
Old 03-19-2013, 01:11 AM   #23
Crazy Butcher
Drives: Yaris 2008
@ Banifesto To get that problem resolved, you have to buy a module Sensor bypasser, you can check it out on Microimage's site, it just plugs in your black box under the passenger seat,when you remove the oem seat you have to unplug a connector off of the black box to get the seat out. just plug the new module right there, then you can switch it on and off. Also the modules are made by CTScott, Shoutout to him by the way!
Old 03-19-2013, 10:00 PM   #24
banifesto
Drives: Yaris Sedan
Thanks for the info Crazy Butcher :)
are all bride and recaro seats can be used in yaris sedan 07? gudboi182 Performance Modifications 5 03-05-2012 05:47 PM
Supercharger, Nardi wheel, Recaro seats!!! jdmekcivic Items for Sale by private party 165 11-18-2010 01:37 AM
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 03:40 PM
Need Seats Opinions Wanted RacerFreakXXX Cosmetic Modifications (Exterior/Interior) 9 02-15-2009 03:15 AM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 06:08 PM
