Old 04-10-2013, 12:18 AM   #19
YarisSedan
Drives: 08 Yaris Sedan
If your are concerned you could take your vehicle to a transmission shop such as aamco that has a transmission flush machine. They disconnect the lines to the cooler and introduce the machine in its place. The dirty fluid goes into the machine and fresh clean fluid goes back in. Dialysis for your transmission. That way you get 100 percent fluid exchange and needs to be only done once. Afterwards they will drop the pan and change the filter and gasket.
Typical cost is about 250
Old 04-13-2013, 02:40 PM   #20
potorap
potorap's Avatar
Drives: 2009 Yaris
Scott,
Bought 6 quarts of WS tranny fluid at the dealer Friday asked for a discount and got it for $7.29 a quart instead of $ 9.33. Drained the fluid today and got 3 1/2 quarts out. Very easy job, I re-used the drain plug and gasket and have no leaks, not sure why some have replaced them. I was reading your comments from another thread that the capacity is 5.68 quarts, is this correct?
Thanks for your help.
Richard
potorap is offline   Reply With Quote
Old 04-13-2013, 05:07 PM   #21
Originally Posted by potorap View Post
Scott,
Richard
The total capacity is 5.68 qts, but the only way to get that much out of the tranny is to disassemble it and drain the valve body and torque converter. A complete pressure flush as mentioned above would change out most of it, or you can run it for a bit with what you changed out, and then drain and refill it again to swap out a bit more of it.
Old 04-13-2013, 10:51 PM   #22
potorap
potorap's Avatar
Drives: 2009 Yaris
Scott,
I travel about 125 miles a day and my plan is to drain it again in about 3-4 weeks, drop the pan, change the filter and refill. Upon reinstallation of the pan, should I use any silicone on the block/pan, or put in on dry? is there a pattern to tighten the bolts and what is the torque specs? Thanks.
Richard
Old 04-13-2013, 11:02 PM   #23
Scott,
Richard
There's an OEM gasket for the pan, so get a new one along with the filter, and no silicone is required. The torque on the pan nuts is only 69 in-lb, which is a whole lot less than you would expect. There isn't a specific pattern for tightening the 19 bolts,
Old 04-13-2013, 11:29 PM   #24
potorap
potorap's Avatar
Drives: 2009 Yaris
Scott,
Man you're right only 69lbs, that's not very much. The wix filter I am looking at has a gasket with it. Do you recomend the OEM gasket only? Thanks for the help.
Richard
Old 04-13-2013, 11:32 PM   #25
Scott,
Richard
That's 69 in-lbs, which is just under 6 ft lbs.
The Wix filter/gasket should be fine.
Old 04-13-2013, 11:43 PM   #26
potorap
potorap's Avatar
Drives: 2009 Yaris
Scott,
Gotcha 6 ft-lbs, thanks again. I will let you know how it goes. Take care.
Richard
Old 05-06-2013, 04:17 PM   #27
potorap
potorap's Avatar
Drives: 2009 Yaris
Ok guys,
Just finished dropping the tranny pan and replacing filter. This was the second draining and I am satisfied with job. I am surprised at the amount of metal in the pan and on the old filter. I do not understand why Toyota doesn't recommend a filter change, except for us to purchase a new tranny.Thanks to Scott for the advice on filter change at 100k. I do feel a considerable improvement in shifting and that I believe was the filter change. Another tidbit I discovered today upon recycling the oil and filter. O'reilly auto parts (west coast only?) sells global ATF which on the back of the quart say it is compatible with WS and it is $6 a quart.
Old 05-23-2013, 12:08 AM   #28
Everglade
Crazy Russian
Everglade's Avatar
Drives: 2007 Yaris RS
Why my 2007 Yaris user manual says - total volume of ATF is 2.5 Litres?
Everglade is offline   Reply With Quote
Old 09-22-2014, 04:15 PM   #29
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
As mentioned above , it is only a drain and re-fill , not a disassembly of the transmission .
frog13 is offline   Reply With Quote
Old 10-17-2017, 12:06 AM   #30
yarisbird
yarisbird's Avatar
Drives: 2007 Yaris HB Bayou Blue
Auto Transmission Drain & Refill 07 Yaris HB
Hi CTScott, do you or any of the forum members know what the torque spec is for the transmission drain plug? I read on another thread that a member tightened the drain plug to 35 lb-ft but that seems excessive. Thanks.
yarisbird is offline   Reply With Quote
Old 10-17-2017, 11:16 AM   #31
thetut
Drives: 2007 4dr sedan
From the manual:
DRAIN AUTOMATIC TRANSAXLE FLUID
(a) Remove the drain plug and gasket, and drain ATF.
(b) Install a new gasket and the drain plug.
Torque: 49 N*m (500 kgf*cm, 36 ft.*lbf)
thetut is offline   Reply With Quote
Old 10-17-2017, 05:43 PM   #32
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
When I spoke with the local Toyota dealership, they recommended only a drain and fill and not to replace the filter. That's how they said they service the transmission. Transmission filters and gaskets are a 'special order' item. I had ordered a filter from Rock Auto and it did not come with a gasket. I cheaped out and am now regretting it. So far, I have drained and refilled 3 times. I am going to have toyota order me a gasket and in a few months I'll replace the filter and top up again. Local dealer sells the Toyota WS for $7.95/L (CAD).
Old 10-18-2017, 09:04 PM   #33
yarisbird
yarisbird's Avatar
Originally Posted by thetut View Post
From the manual:
Thanks!
Old 10-19-2017, 04:05 PM   #34
thetut
You're welcome. Good luck with your Drain and Fill.
Old 10-21-2017, 08:05 AM   #35
white89gt
Drives: 07 Yaris Hatch
My Yaris was given to me by a family member that purchased it new, and never serviced the trans. I got it with 121,000 miles on the clock - so I did it myself. My Buddy that owns a transmission shop just happened to come over in the middle of me changing the fluid. My initial intent was to do a drain and fill, but he talked me into dropping the pan and filter. Boy was I happy he did. The OEM filter was nearly plugged. Black stuff was all over it inside.... it was clearly doing its job.
I live about 35 miles from his shop, so we just got a filter and gasket kit from O'Reilly. Not a very high quality set, but better than what I was dealing with. I am going to change it again in a couple months with a Toyota filter, but I thought I'd share that info with you.
Also of note... I used Valvoline Maxlife in it, and it drastically improved shifting. I also needed just under 5 quarts to fill it. I am guessing that the converter drained some out as well - because it sat draining for an hour or so while I went to the part store.
white89gt is offline   Reply With Quote
Old 10-21-2017, 04:48 PM   #36
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Which engine do you have? 1NZ-FE (1.5l) or 2NZ-FE (1.3l)? The different engines have a different auto transmission and use different fluids.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
auto transmission fluid change bribri DIY / Maintenance / Service 4 01-01-2012 10:39 AM
Super Amazing Oil Change DIY id3379 DIY / Maintenance / Service 34 11-28-2008 01:20 PM
