Old 04-08-2013, 02:47 AM   #1
Slacky
Slacky's Avatar
Drives: 2007 Yaris Sedan
Rubber hanger for Sedan with DCSport Item #: SCS7041
Quick question:
This axle-back exhaust will be arriving this week and I need to know what size of rubber hangers I need to purchase since I have the S body kit??
Slacky is offline   Reply With Quote
Old 04-11-2013, 09:26 AM   #2
Yarisaur
Drives: 07 Yaris
You shouldn't need new hangers, the DCsport axle back hangs low on the sedan to accommodate the Type S. I have the Base sedan and I had to buy shorter hangers to move the Dc closer to the bumper. Just put it on and see if you have enough clearance and go from there!
Yarisaur is offline   Reply With Quote
Old 04-11-2013, 12:52 PM   #3
YarisSedan
Drives: 08 Yaris Sedan
You can try using a hose clamp around the hanger to remove some of the slack and play. Its a old trick people would do as a cheaper and alternative method to poly hangers
Old 04-11-2013, 12:53 PM   #4
YarisSedan
Old 04-11-2013, 12:53 PM   #5
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
The stock hangers should drop it low enough.
Old 04-15-2013, 03:53 AM   #6
Slacky
Slacky's Avatar
Excellent! I just saved around 39.00 dollars.
Thanks
Old 04-15-2013, 04:07 AM   #7
Slacky
Slacky's Avatar
Thanks
TRD exhaust hanger issues....check yours Gogogordy DIY / Maintenance / Service 4 11-08-2012 08:22 AM
Classifieds Suggestion RogueYaris Suggestions - Feedback - Questions 21 06-27-2007 12:14 AM
