#109 |
Banned NOT!
Drives: Car Join Date: Jan 2010
Item: muteki sr48 purple nib
Seller: jtf1986 Date purchased: like 2 weeks ago Date arrived: 4 days Comments: had to pay over western union... But. Awsome price! Awsome communication! Ill definietly will make deal with him again without questions!! |
#110 |
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
item: Viper Alarm
seller: djgab101 comments: seller was great, all pm's were answered and great support. shipped right away and took little time to come from australia. great seller and great packing job. i would definietly make another deal with the seller again and recommend him to others. A+++
#111 |
Item: Micro Image custom side markers
From: Tylermayer Date Purchased: October 27, 2011 Date Received: October 29, 2011 Comments: Holy fast shipping! Arrived well packaged and in great shape!
#112 |
![]() ![]() ![]() Drives: 2010 Prius, 2007 Yaris Sedan Join Date: Oct 2009
Item: Tanabe NF210 springs
Seller: Shinare Date purchased: 12/6/2011 Date arrived: 12/10/2011 Comments: Good packaging, shipped via FecEx with no problems. Great communication. Would not hesitate to deal with again. |
#113 |
Pirate Yaaaaris
Drives: '00 Toyota Celica GTS 6MT Join Date: Aug 2009
Item: MI HID Projectors, 55w Nokya Yellows
Seller: Garm/Micro Image Date purchased: 12.31.11 Date received: 01.07.12 Well, aside from a whole year changing over (haha ), another quality product from our resident quality vender. Now to just get over the fear of hacking into my only set of headlights. XD-C
Georgia Bulldogs! ![]() '09 Yaris LB 5MT Sold. |
#114 |
![]() Drives: 07 Yaris Sedan Join Date: May 2012
Item: Megan Racing Coil Overs
Seller: Garm/Micro Images Date Purchased: 5/9/12 will post update when I recieve my package. Called directly to confirm stock of this item and was told yes. Then went ahead and placed the order, called Megan Racing direct and they are out of stock until the end of the month... Fingers crossed lol |
#115 | |
Only Happy When it Rains
Oh I'll add for fun. Item: Megan Racing Coil Overs Seller: Garm/Micro Images Date Purchased: 4/5/12 Date Recieved: around the 15th or so, Talked to Jeff and they had run out of everything. So I called Jeff @ MI before I bought to talk about Coilovers, and he took at least 45 minutes to walk me through everything. We decided on what I wanted to do, and I ordered it. I just had my normal mechanic with no real coilover/racing parts experience put them on, and Jeff took the time to call them and spend as much time as they needed to understand everything. As usual MI goes way beyond what a normal internet shop would ever do.
Colin Chapman disciple |
#116 |
@ SedanDan: Megan is out because we took all of their stock. LOL
#117 |
RECEIVED my coil overs today!!! thanks so much for your help! unless you know how to get those pesky lower bolts off that clamp around shock assembly? :)
#118 |
Mr. 155 and climbing
Item: Full Engine 1NZ-FE
From: New England Auto Parts of Unity, Maine Date Purchased: May 2012 Date Received: May 2012 Comments: Even though this place isn't a YW or MI vendor I wanted to provide my input as this vendor is selling a lot of items on both car-parts.com and eBay. I blew my original motor and began my search for a replacement motor immediately. I was referred to check out NEAP as they were very close and had what looked to be a good price. Working with NEAP I really can't complain when it comes to communication. The normal warranty for a short block, long block, or full soup to nuts engine is 1 month or 1,000 miles. The issue that arose for me and has caused me a great deal of heartache and headaches was the engine that I received. The motor arrived well wrapped and braced. All holes were plugged and the engine did look to be what had been relayed in that it had roughly 23k miles on it. When I spoke with NEAP I told them that I didn't mind paying a fair price, but wanted to be sure that what was shipped was in 100% working order. I was assured this was the case. The water pump pulley was bent so that was not able to be used. The pulley wheel that sits so that the top of the pulley rather than the ribbed side was bent. The major issue that comes into play was that on the passenger's rear side of the oil pan assemblies you could readily see that it had been damaged and warped. The lower pan was not salvageable and the upper looked to be fine. I spoke with NEAP on the issue and the response was that a warranty exchange for the part could not be completely unless the engine was run and proved to be leaking or there was some other apparent issue. This required me to take the time, money, and energy to install the engine. After installation...to give you the short version...it has been discovered that the upper pan just above the passenger rear bolt hole has a crack in it most likely from the hit that the engine took. I spoke the first week of June to NEAP about my suspicions that the upper pan was possibly bent not suspecting it was a crack and chased my tail on it. In the meantime NEAP did send me a replacement upper and lower pan however once again the engine will have to come out of the car and upper pan then replaced which is not an easy or cheap task. It will require removing the timing chain cover, upper pan, o-rings and gaskets. I still will need to bring this up and attempt to get them to assist with covering that installation cost as we discussed at length that I needed a 100% working and worry free engine. I was assured that I would get a solid item and then after a few calls the statement finally came up from them of, "well, you know that you are buying an engine from a wrecked car." ![]() I should have went with my gut and just sent the engine back to NEAP not accepting it, but in my haste to get back on the road I didn't pay heed to my inner voice. All in all I am not saying to stay away from NEAP, but I would strongly suggest that anything you purchase from them you scrutinize and go with your gut if you think something is awry. Do not let them try to placate and sweet talk you. http://www.newenglandautoparts.com/
#119 |
![]() ![]() Drives: 2007 3dr hb 5sp Join Date: May 2012
Bought from ; VTEN
Item: AEM cold air Very happy, fast shipper! |
#120 |
![]() ![]() ![]() Drives: 2010 5 Door Join Date: Feb 2011
Item: TRD Exhaust
From: Jerkratt Date Purchased: 9/23/12 Date Received: 9/23/12 Comments: real good guy, even helped me install it! couldnt be happier
lol okay |
#121 |
Item: led door sills
From: kargoboy Date Purchased: 1/11 Date Received: 1/17 Comments: instructions arent very clear because theyre in black and white and confusing translations, but the product is great! thanks kargoboy
lol okay |
#122 |
2ZR swap. DO IT! Ask how!
Item: Blitz supercharger (used)
From: Bubbles Date Purchased: 18 Feb '13 Date Received: Scheduled delivery 22 Feb '13 Comments: Five Stars! Buyer was prompt in replying to PMs. Will update with product info once I get my hands on it. Buyer included spare 8-rib belt at no cost. |
#123 |
Forgot to do this!
From: Crackerballer Date Purchased: 30 Dec 2012 Date Received: ~7 Jan 2013 Comments: Awesome seller, shipped quick (barring the New Year's holiday, problems beyond his control), responded to PMs quickly.
#124 |
![]() ![]() Drives: 2008 toyota yaris hatchback Join Date: Dec 2012
Item: cold air intake
From: dperry Date Purchased: feb 15 2013 Date Received: feb 21 2013 Comments: very well priced and very comfortable person to work with about time and shipping requests. i got what was expected and love it :) |
#125 |
http://yarisworld.com/forums/showthread.php?t=44296
Item: OEM Yaris sedan headlights From: LA Yaris Date Purchased: April 10, 2013 Date Received: April 11, 2013 Comments: refer to link above...this is not a positive purchase for me. |
#126 |
Stoplight ahead!
Drives: 2007 Flinty Yaris Sedan Join Date: Aug 2009
Item: OEM Yaris Sedan Taillights
From: LA Yaris Date Purchased: April 10, 2013 Date Received: April 12, 2013 Comments: Taillights arrived cracked and dirty. Requested and awaiting refund. Refer to link http://yarisworld.com/forums/showthread.php?t=44296 for pictures. |
| OFFICIAL Yaris SEDAN thread | SimmZ | Photo-Video-Media Gallery | 1706 | 06-22-2025 05:33 AM |
| Post Whores-aka Yaris chat thread | Black Yaris | Off-topic / Other Cars / Everything else Discussions | 21 | 07-12-2007 05:37 PM |
| VANCOUVER - MEET - READ THIS THREAD FOR INFO. AND FEEDBACK | bigsky2 | Canada | 94 | 01-29-2007 02:42 AM |
| US Yaris Sales "stronger than expected" | GTSRacer | General Yaris / Vitz Discussion | 16 | 09-16-2006 01:35 AM |
| there everywhere | punch | New YARIS Purchase Forum | 9 | 05-30-2006 05:02 AM |
