Old 05-24-2013, 04:54 AM   #1
peewee1
PEEWEE1
peewee1's Avatar
Drives: 2009 yaris s sedan
change tranny fluid
After draining off @3 quarts of tranny fluid, and its time to add new fluid, should the engine be running? And should the tranny be in park or neutral? I plan to rejuvenate the tranny fluid without going for a complete flush ($250.00) Please no lectures on fluid changing--the questions are: engine off or on, transmission in park or neutral or gear? Thanks for the input Yaris people.......
peewee1 is offline   Reply With Quote
Old 05-24-2013, 06:08 AM   #2
Add the fluid to the low mark before starting the engine. You would not want to spin the tranny 3 quarts low. Once it is to the low mark, start the engine, put the tranny in neutral, and let it run for a few minutes. Then, check and add.
Old 05-24-2013, 08:30 AM   #3
peewee1
PEEWEE1
peewee1's Avatar
thanks
Automatic Trans fluid change interval? charles nelson DIY / Maintenance / Service 2 02-08-2013 07:25 PM
transmission fluid that indicate must change susucosp DIY / Maintenance / Service 3 12-10-2011 11:51 PM
when do I change tranny fluid? phyrefighterjay DIY / Maintenance / Service 1 10-23-2011 02:19 AM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
soo whos gonna change their tranny fluid twixt DIY / Maintenance / Service 0 08-04-2006 03:09 AM
