Drives: Yaris D4D T Spirit Join Date: May 2013
The spanner
Hi all
Not sure if this is a known issue. I have just bought a Yaris d4d tspirit 2011 under 13,000 on the clock from a toyota dealer. All good very pleased with car. Whan I took delivery of it within the first few miles the spanner appeared on the dash blinking regularly. Now the dealer said the car was safe to drive and that it had had a full service as part of used car deal. Is there any reason you know why this light might come on apart from that it needs a service/change of oil ? Puzzled I am.
I finally found part of the service manual that describes the indicator lights for the European Yaris. The spanner (wrench) indicator is the "Oil change reminder light".
I am not sure if it is the same for the European one, but for the US on to reset it you: 1. With the ignition on switch the odometer to the Trip A display. 2. Turn the ignition off. 3. Hold the odometer switch in and turn the ignition on. 4. Continue holding the odometer switch until the odo display stops flashing dashes and starts flashing numbers.
| Tags |
| diesel, spanner, warning light, yaris |
