Old 06-11-2013, 11:13 AM   #19
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Originally Posted by junorico24 View Post
Exactly, the quality of tools you use can also have an impact. I used a poor mans socket set but with a that tyre
nut loosening thing ma gee! lol it worked but i stripped it without the 4 way tire nut cracker extension.
Guilty as charged. All my tools are "el cheapo" as I MAY use a socket once or twice a year.
I started out with a many pointed socket and when that started to slip I changed to a 6 point 14mm I found under a bunch of other sockets I didn't know I had. It looked pretty cheap as well tho. No brand name even on it heh. Then it started to turn on the head... guess I should have started with the 6 point. Live and learn... heh
Old 06-11-2013, 11:39 AM   #20
esse10
Drives: 2009 yaris 2 door
bp blaster
I use BPblaster spray everytime I work on my suspension and it works like a charm for removing bolts. By the way all you needed was a high grade bolt at the local hardware store, grade 8 - 10 hardened steel. It would've been cheaper than the dealer price for sure. If you gonna do your own mechanic work you might want to invest in some good quality tools, makes a diffirence.
esse10 is offline   Reply With Quote
Old 06-12-2013, 01:10 AM   #21
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
It's PB Blaster and I freakin love the stuff! Been using it for a decade...it even smells good in my opinion.
-Type 07 FFL-
My odometer 03/11
Old 06-12-2013, 08:46 AM   #22
esse10
ya know
Yea whatever you know what I meant. I don't think it smells so good but sure get's bolts loose quick quick
Old 06-12-2013, 09:24 AM   #23
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Also make sure you tighten it up real tight to avoid that ear bustin squeal!
Old 06-15-2013, 10:07 AM   #24
Shinare
Shinare's Avatar
Got the bolt finally but forgot to ask what to torque it to. Anyone know.
Old 06-15-2013, 11:35 AM   #25
UberSilver
UberSilver's Avatar
It does not matter if you use a socket once or twice a year! If it's cheap(India, China), it will cost you more time then the cost of a fancy socket set.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
Old 06-16-2013, 05:34 AM   #26
junorico24
junorico24's Avatar
Don't use Dayco's drive belt. It has a habit of stretching. Stay with Toyota's belt.
Old 06-19-2013, 04:26 PM   #27
esse10
belt
That tends to happend if it's not properly tightened in the first place, like over tensioning the belt. Toyota could have put a tensioner pulley to make things easier on us.
Old 06-23-2013, 06:11 PM   #28
Shinare
Shinare's Avatar
Well, bolts out and belt is on!!!!! Thanks to all here tht helped me. I finally broke down and bought the expensive roundedbolt set from pep boys as pictured. It finallybroke loose after many squirtsof liquid wrench and a long cheater bar. (Thought i had broke the bolt or wrench how loud it snapped when it finally broke.) Thans again everyone for the support and ideas that gave me the courage to tackle what i thought was an insurmountable problem.
Ps there was this white powder in the threads of the bolt. Some gift of thread lock from someone previous?
Need new Serpentine/Auxilliary belt ras3448 DIY / Maintenance / Service 21 07-16-2013 05:11 PM
DIY how to change you belt in 10 minutes without breaking VVTI solenoid YarisSedan DIY / Maintenance / Service 2 04-12-2013 10:41 AM
Broke Part on Engine Changing serpentine belt. theeggrocks DIY / Maintenance / Service 5 04-16-2012 12:27 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
