Old 06-11-2013, 10:04 PM   #1
Kazimodo
Kazimodo's Avatar
Drives: Yaris 2007 3 doors
Exhaust leak
Some days nothing works ...
for a long time now ,( over a year) I've had exhaust noise
from the rear of the car , I knew there was another donut
back there like the one I change in the front , yesterday
I decided to do it .
got the donut , part number : 17451-23042
said no to the 2 bolts ( mistake)
when I did the front , I bought the 2 bolts
but they where not so bad ,
so I tought the rear ones would be OK
I broke one ,even with liquid wrench on it snap!
car well designed slide muffler off the rubber supports
and bring to vise to work on broken bolt.
redrilled , retaped , 10 X 1.25 thread , got a
regular 10X1.25 bolt at auto part ,( 2$ )
reassemble evrything , and the big roar is still there
next day drive for an hour , should be enough for new donut
to sit properly , but no, still the big roar of the 1500 cc engine.
roll under , put a small mirror in the area of the donut , then
the mirror got all foggy when I put it 6 inches away from the
donut , hot air from a leak ,under a small plate ,welded to the
tail pipe, bring inside to see better ,just under
the small welded plate that serves an unknown mysterious purpuse
were 2 holes big as the nail on your index finger , remove plate
and using and old piece of exhaust pipe that was too big,
I made a patch , got 2 U-clamps and I should be OK for 2-3 years .
What is the prupose of the mysterious plate ????
Kazimodo is offline   Reply With Quote
Old 06-12-2013, 12:17 PM   #2
taka
Drives: 2008 Sedan
Great repair. That plate look like a heat shield for that flex hose (brake?) just on top of the exhaust pipe on your photo. You may have to put some other shielding in place just in case.
taka is offline   Reply With Quote
Newbie with an exhaust leak on his '06 Yaris ToYarta DIY / Maintenance / Service 49 01-03-2019 01:50 PM
Just a Wee exhaust leak WeeYari DIY / Maintenance / Service 12 09-02-2015 04:24 PM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 09:02 AM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 10:23 PM
