Old 06-29-2013, 01:15 AM   #109
Originally Posted by jayeh View Post
I just took mine to be installed today and the installer took one look and said its a cheap Chinese knockoff. Any ideas?
I have no idea why he would say that, as it is genuine OEM stalk. The only thing that might have made him question it is the horn wire, which I add, to save people the hassle of breaking the pin to pull their's out of the original connector.
Old 07-03-2013, 09:45 AM   #110
isidoro
Drives: HDS
Hello CTScott
I write from another part of the world “italy”
I are desperate
I know that we are talking only of yaris
but you are the experts on Cruise Control that I found
I own a hybrid Auris HSD 1,8L
I put all the parts needed as the model with the standard Cruise Control
when I press the button on/off, the lights Cruise Control lights up green
but just release the brake I get a yellow triangle and the following “check Cruise Control “
do you have any advice for me???
thanks so much in advance
foto http://tinyurl.com/nfsms5n
isidoro is offline   Reply With Quote
Old 07-03-2013, 03:43 PM   #111
Originally Posted by isidoro View Post
Hello CTScott
I are desperate
I will have to do some research for you when I return. I am currently in Northern Europe on holiday.
Old 07-03-2013, 04:02 PM   #112
isidoro
Drives: HDS
OK
good vacation
we update when you return
Isidoro north italy
Old 07-10-2013, 09:54 AM   #113
isidoro
Drives: HDS
while visiting europe
if you go to Northern Italy
I'll pick you??
I am close to Bergamo, which has the largest airport
where land all European flights
Bye-Bye!
Old 07-10-2013, 03:55 PM   #114
rapev-8
Drives: toyota
do u have anymore?
rapev-8 is offline   Reply With Quote
Old 07-11-2013, 12:43 AM   #115
I'll pick you??
Bye-Bye!
I am a bit more North: England, Denmark, Sweden, Estonia and Russia.
Old 07-11-2013, 12:45 AM   #116
Originally Posted by rapev-8 View Post
do u have anymore?
Yes
Old 07-13-2013, 01:42 PM   #117
Jadijkstra2000
Drives: Toyota Yaris 2010
Do you have more? :)
Jadijkstra2000 is offline   Reply With Quote
Old 07-13-2013, 04:47 PM   #118
Yes
Old 07-14-2013, 04:19 AM   #119
Jadijkstra2000
Will it work on european Yaris 2010?
Old 07-14-2013, 06:30 PM   #120
Hayabusaboy
Drives: 2007 white hatchback
Was reading thru a few treads, seems your saying that all yaris have the hard wiring from the factory, correct? I have a 07 hatchback auto trans. If all i need is this kit your selling i'd like to purchase one, if you still have some available. Pay pal ok? Thanks Bruce
Hayabusaboy is offline   Reply With Quote
Old 07-16-2013, 08:47 PM   #121
lanemeyer14
Drives: 08 base Hb
I'm interested in one as well if still available. Will be for an 08 liftback 5spd
lanemeyer14 is offline   Reply With Quote
Old 07-16-2013, 10:13 PM   #122
My understanding is no, but a person from Germany recently ordered one from me, as he was told that it would work. I will let you know when I hear back from him.
Old 07-17-2013, 09:17 AM   #123
Jadijkstra2000
Number of the ECU is : 89661-0dd90
Hope it can work :) Would be nice
Old 07-18-2013, 05:57 PM   #124
Jadijkstra2000
It looks like the car already has the clutch switch installed, i cannot have it started when the clutch is not pressed... So i guess that one is installed...
Old 07-18-2013, 09:03 PM   #125
The cruise control clutch switch is different. The starting one requires the clutch to be pressed completely to trigger, where the cruise control one triggers as soon as the clutch switch is touched.
Old 07-21-2013, 08:01 AM   #126
Jadijkstra2000
ah alright, didn't know that, thanks :) are there ways to check if the car is prepared for cruise?
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
Can we do this? (aka The DIY Cruise Control Thread) mrbond DIY / Maintenance / Service 502 07-22-2017 02:57 PM
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 08:09 AM
