Old 08-09-2013, 07:36 PM   #19
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
The cluster gets constant power from the ECU-B fuse and switched power from the MET fuse and illumination power from the PANEL1 fuse. It also gets a power feed from the HAZ fuse, as it directly drives the turn signals.
The IG2 Relay feeds the MET fuse power.
If all of those fuses are good, check the voltage on the light blue (ECU-B) and pink (MET) wires, which are right next to each other on one corner of the larger cluster connector. The ECU-B should have power all the time and MET should have it only when the ignition is on.
Ok... with the key switch in the ON position, there is no power to:
the MET fuse
the IGN fuse
the IG2 fuse
Here is the engine compartment fuse box layout:
There is power to the ECU #1 fuse under the dash.
The under dash registry.
I used an AM radio to pick up powered and unpowered fuses as it "ticks" when they are removed and reinstalled. on the ones that didn't tick, I confirmed no power with a multimeter.
Old 08-09-2013, 09:02 PM   #20
tooter
play every day
tooter's Avatar
I tried a test. Removed the MET fuse, stuck a spade terminal in the socket and jumped it to the positive battery terminal. The dash gauges turned on. Put everything back together and it's still the same no go...
Old 08-09-2013, 10:38 PM   #21
OK.
Power flows to the MET fuse as follows:
1. 80A MAIN fuse on positive battery terminal
2. 50A R/I Fuse
3. Contact of IG2 Relay
IG2 relay coil power flows as follows:
2. AM2 Fuse
3. Power enters ignition switch connector on white wire (AM2)
4. Pink wire on Ignition switch connector (IG2) feeds the coil
I missed the R/I fuse when I was looking before. Check him next, and if it is not him follow the two flows above.
Old 08-09-2013, 10:53 PM   #22
tooter
play every day
tooter's Avatar
Ok. I'll check the chains of command. Ok. Found the 50 amp R?I. A red single.It takes a real wiring catastrophe to blow a big fuse, so I sure hope it isn't blown.
edit: It's good. I'll go through the others tomorrow.
Old 08-09-2013, 11:08 PM   #23
It should be one of the big boys in the under-hood fuse panel. Actually it is the square red one between the 7.5A and 20A fuses on the right side of your picture above.
Old 08-10-2013, 11:47 AM   #24
tooter
play every day
tooter's Avatar
Yes. Checked the 50 amp last evening and it's good. I'll check the rest today.
Old 08-11-2013, 04:16 PM   #25
tooter
play every day
tooter's Avatar
Bingo, Will.
AM2 fuse. Everything works fine now. the most likely reason is that I was defeating the clutch pedal start disable switch and I'm pretty sure that the ignition switch was in the ON position while I was doing it.
Thanks so much for taking your time to offer such a precise troubleshooting sequence.
Regards,
Greg
When cold starting, almost sounds like opening a fresh 2-liter Coke bottle Shinare DIY / Maintenance / Service 8 06-03-2013 04:18 PM
2009 Yaris starting issue -need help cudchew DIY / Maintenance / Service 15 12-16-2011 02:24 AM
Yaris Starting Mystery – Help Please! ceilingwalker DIY / Maintenance / Service 3 11-10-2011 05:35 PM
Problems starting the engine fmicle General Yaris / Vitz Discussion 10 10-07-2009 08:48 AM
Starting Engine - Yaris Hatchback M/T gbuks General Yaris / Vitz Discussion 2 11-06-2008 12:24 PM
