![]() Drives: echo Join Date: Aug 2013
Charcoal Canister removal help
Hello All,
I am stuck trying to remove my charcoal canister. I am not sure how to remove these two connectors. I can see of the smaller of the two that it looks like you should squeeze the tabs together and the hose should come off but for the life of me I cannot seem to manage to get it to budge. The larger one I have no clue how to tackle. Looks as if the connector needs to be broken to remove??? ![]() ![]() ![]() ![]() Thanks |
I just took the one off of the Yaris that I am parting out, so I have first hand experience with this. It is bit of a hassle to get that big guy off. You are supposed to just have to squeeze the flats at the point furthest from the canister, but for the life of me I could not get it. The whole connector stays together by the way.
If you look closely you will see two barbs on the canister that the connector latches onto. I ended up taking two tiny flat blade screwdrivers and slipping them up from the canister side to release the part that catches on those tabs. Once I did that it slipped off with no problem. With the little guy, you have to push the connector in before squeezing the tabs and then you can squeeze them and slide it right off.
Thanks CT.
I hope I can get this bastard off. This is a pain in ass to do laying on your back. :P |
Unbolt it first, then you have enough play is the hoses to work while sitting.
Mr. 155 and climbing
So in all honesty is there really a true need for the canister if you have one that has failed?
If you don't have it you will eternally have a CEL and will not be able to pass emissions if your state does testing.
#7 | |
I just figured that I would bring that question up since folks do have them that are failing. I am glad that it won't be a concern for me.
Yes,
I need to it pass estest. They no longer do the sniffer test here on cars newer then 1997. CEL on = automatic fail. |
| Vapor Canister | Crashmaster | DIY / Maintenance / Service | 25 | 03-11-2014 10:18 AM |
| Wanted: 2008+ Charcoal Canister Assembly | D&D | Willing to Buy by private party | 4 | 02-17-2012 10:46 PM |
| Removal of the Factory Integrated Source | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 08-24-2010 12:44 AM |
