Old 08-17-2013, 01:24 AM   #1
nerdyguy
Drives: 08 yaris
Front led Turn Signals
I have an 08 hatchback and I want to look for some led turn signals. I couldn't find any on ebay. Anyone know where to get some for a decent price? Thanks.
nerdyguy is offline   Reply With Quote
Old 08-18-2013, 07:22 AM   #2
jcboy
Drives: Sedan 07
decent price, i dunno. but the stealership here does sell those as an add on accessory, some local auto accessory shops do and are cheaper but usually in chrome rather than paintable black abs plastic.
i should say that those on ebay (if you ever find one) are the same if they are accessory as compared to OEM side mirror assembly replacement--they stick onto your existing covers, and they don't look good. they look like your mirror housing turned uber-fat. lol
any country but japan would be a good place to look imports from, if you're only after the cover (with turn signal, not LED though replaceable with) and not the entire assembly (power adjust AND power retract). otherwise, i believe philippines is the only big market of these yarises that are LHD.
Old 08-23-2013, 01:58 AM   #3
jeeper5usa
jeeper5usa's Avatar
Drives: 2011 Toyota Yaris
www.superbrightleds.com
jeeper5usa is offline   Reply With Quote
Old 11-19-2013, 05:30 PM   #4
09cptn
Drives: 2010 Yaris Sedan
Are these difficult to install? Looks like you need some sort of unit to make flashers work? What's up with that?
The Yaris: 2010 Yaris base model. 50% tint up front and 35% in the rear, Konig Lace wheels with homemade Toyota center caps on Yoko S.drives, Curt hitch.
Offroad: 2004 Jeep Wrangler lifted on 33's
09cptn is offline   Reply With Quote
Old 11-19-2013, 05:47 PM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
Because LED does not put the electrical load as incandescent bulb does, hence you will flash double the speed, indicating a dead bulb.
You could either put a resistor (CTScott probably can tell you which one you need), but i went with this when i was using LED bulbs as turn signals..
http://www.ebay.ca/itm/8-Pin-LED-Fla...0cc3c1&vxp=mtr
Old 11-19-2013, 06:21 PM   #6
jcboy
Drives: Sedan 07
just realized my response to this thread was about side mirror turn signals.
anyway, yes LEDs don't provide enough load on the circuit, and for a circuit designed to flash faster when there's a busted bulb (lower load/resistance read by the flasher relay), then you'll need a resistor to have the flasher relay realize there's no busted bulb.
Old 11-19-2013, 10:36 PM   #7
09cptn
I just need one of those, and I can install LEDs all over the car? Also, the website said something about not using LEDs in the headlight housing?
Old 11-20-2013, 02:26 PM   #8
Klink10
Klink10's Avatar
My parking lights in the "headlight housing" have had LEDS for years. No issues.
Old 11-20-2013, 04:11 PM   #9
IllusionX
the sedan doubles as flashers. there will be issues.
Old 11-20-2013, 05:14 PM   #10
09cptn
What is the issue? The halogen headlight is too hot and hurts the LEDs? What if I just made the headlights and everything LED? LEDs are cool to the touch, right?
Old 11-20-2013, 05:14 PM   #11
Klink10
Klink10's Avatar
Ahhh....didn't catch sedan. Sorry
Old 11-20-2013, 05:16 PM   #12
09cptn
I'm confused.
Old 11-20-2013, 05:50 PM   #13
IllusionX
25W CREED LED lights will run hot.
the issue is not the heat.. it's the load the put on the circuit is not the same as standard light bulbs, hence you will get a fast flash when using your flashers.
to fix this, you will need to either put a resistor on the circuit OR get one of those LED flasher relay off ebay.
Old 11-20-2013, 08:29 PM   #14
09cptn
Okay, I get that part but why do they say don't use them in headlight housings? What causes them to burn out so quickly?
Old 11-21-2013, 01:56 AM   #15
deathwisher
Drives: 2007 Yaris Sedan
Regular 4pin LEDs are sensitive to heat. Your halogen bulbs produce quite a bit of heat which will reduce the life span of the LEDs.
LEDs are not meant to run at hot temperatures. If you ever look at any of the LED lights on cars and those lights sold at HomeDepo, they all have massive heat sinks.
deathwisher is offline   Reply With Quote
Old 11-21-2013, 08:11 AM   #16
09cptn
What if I replaced the halogen headlights with LEDs too?
Old 11-22-2013, 11:52 AM   #17
jcboy
Drives: Sedan 07
TBH you'll have to try and see for yourself, but LED headlight bulbs are not very bright. some are a bit brighter than halogen, some are less bright, but none have been exceptionally bright (except for OEM ones like Audi r8 lights).
deathwisher is right, heat shortens the LEDs' life span.
actually in the sedan it doesnt double as a flasher, the park light and flasher just happens to be side by side in the same contour under the main headlight. either way, the first issue with the flasher is actually the load on the circuit, thus the fast flashing.
In a nutshell, you are free to put LEDs and it WILL work. the 1st and more immediate question is the fast blinking--so you'll need to add the resistor that has been mentioned. the 2nd and not necessarilly a cause for concern is the lifespan.
HTH
Old 11-22-2013, 12:09 PM   #18
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
Wait, sh!t is about to get serious!
http://www.aliexpress.com/item/2013-...373619269.html
I bet there are also some which fit into the Yaris.
Thanks to some retarded moronic laws, these are sadly not street legal here in borning ol' germany.
The ticket I'm risking by using them would be about 60$ iirc
dj92 is offline   Reply With Quote
Side turn signals. Has anyone done this...??? Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 18 02-27-2013 02:42 PM
Who's got an LED flasher module? Lil Abner Cosmetic Modifications (Exterior/Interior) 7 08-07-2011 12:57 PM
Green 24 LED Turn Signals 7440 fnkngrv Cosmetic Modifications (Exterior/Interior) 15 08-02-2010 12:04 AM
MY GTI Front bumper plus WICKED turn signals.. marcus Cosmetic Modifications (Exterior/Interior) 33 03-27-2009 08:59 PM
Toyota Yaris Door/Mirror LED Safety Turn Signals S Blenjar DIY / Maintenance / Service 1 01-13-2007 08:51 PM
