Old 08-25-2013, 01:28 PM   #271
Hershey
Does anyone have the clunking of the front end after the 2 bolts were replaced ?
Old 08-25-2013, 08:51 PM   #272
Hershey
Another thought . Will the sedan need an alignment if the front suspension is repaired ? Would think so .
Old 08-25-2013, 10:19 PM   #273
Not if just the bolts are replaced. If the full service is done where they drop the A arms and seal the seams, then alignment should be done.
As another thing to worry about, today I was finishing my disassembly of the Yaris I am parting out. The front bolts were perfect (this is a 2007 California car that appears to have never even made contact with water with how perfect all metal parts have been).
When I dropped the rear axle beam I noticed that one of the bolts that mounts it to the body had a significant spot of corrosion. This was the only bolt on the entire car that had a hint of rust. This makes we want to take a peek at the ones off my Yaris which have seen lots of Winter salt.
In this picture the long ones on the left are the rear beam bolts and the right ones are the A Arm bolts:
Old 08-26-2013, 08:06 PM   #274
NEexpat
Drives: 2009, auto, 4dr LB
^ I'd be interested to know what you discover on your cars Scott.
That spot high up on the thread like that, not good, very odd considering the condition of the rest of the car.
Perhaps just a bad bolt.................................or is there some sort of design flaw with the rear axle beam like with the A arms, great now I'm going to go slide under my car and look about.
NEexpat is offline   Reply With Quote
Old 08-26-2013, 09:54 PM   #275
bronsin
bronsin's Avatar
You know I just want to express appreciation for this site which keeps us so well informed about the (relatively minor) problems with our cars. My hat is off to you all!
Also my thanks to Toyota for making the Yaris the quality, practical car that it is. You should read some of the problems cars on other sites are having!
And REALLY read the problems BMW motorcycles are having at The Chain Gang.com!
Old 08-27-2013, 08:37 PM   #276
Hershey
CT, are the bushings visible or easy to view for inspection ? A relative has a lift in his garage and is a mechanic. What should we look for if the bushings are bad ? Thanks
Old 08-27-2013, 09:01 PM   #277
The bushings around the bolts are easy to see, but I don't think you will see anything obvious. I think you will need to try to recreate to motion while listening closely to catch the noise.
Old 08-27-2013, 10:06 PM   #278
Hershey
Do the techs use a listening device when moving the arms up and down while on a lift to pinpoint the noise? How long would it take to determine the source ? May have to take it to a dealer and would like to know what to expect. Thanks for all of your help.
Old 08-27-2013, 10:21 PM   #279
My bet is they will shake it or road test it and tell you there is nothing wrong and that the noise is normal.
Old 08-27-2013, 10:35 PM   #280
Hershey
That's quite possible since it's warranty work and a big job.
Old 09-04-2013, 01:59 PM   #281
DonM
Drives: 2008 Yaris sedan, 5 speed
I was going to sell my 2008 Yaris sedan but changed my mind so I went ahead and purchased the control arm bolts from my local Toyota dealer for $17.50.....and I am glad that I did (refer to the photo)......I took it took to a Midas dealer for an oil change and they swapped out the bolts for free - considering that my car only has 47,500 km on it and has not seen a lot of winter driving - I would hate to see the bolts on some of the high milers that are driven in the rust belt.
Don't wait for the clunking sound to appear - do it now since it costs so little to do.
DonM is offline   Reply With Quote
Old 09-05-2013, 12:22 AM   #282
Hershey
^ Good thinking ^ . We believe the creaking / clunking in the front has gone since the replacement of the bolts . Still have it coming from the rear . At least it's not in stereo for now .
Old 09-15-2013, 11:45 PM   #283
camh
Drives: 2008 Toyota Yaris
My daughter's car was less than 34,000 miles when her right control arm broke.
camh is offline   Reply With Quote
Old 09-16-2013, 12:43 AM   #284
nookandcrannycar
Ugh. Is your daughter also in New Jersey or a similar location re winter road maintenance that might contribute to the control arm issue?
Old 09-17-2013, 06:36 PM   #285
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
No, I haven't heard it since they replaced my bolts.
DebbyM46227 is offline   Reply With Quote
Old 09-22-2013, 08:42 PM   #286
WildChild
Warranty extention in Canada?
Hi,
the passenger side's bolt snapped last week on my 2007 sedan. After hearing the clunking noise when driving over bumps during the weekend, I looked under the car and found out that the bolt was missing.
I see in this thread that the warranty was extended to 100K miles (160K KM)/7 years for this issue in the US. My car 6 1/2 years old and has only 77K KM. Does anyone know if the warranty extension also applies to Canada?
Thank you!
WildChild is offline   Reply With Quote
Old 09-22-2013, 09:43 PM   #287
Originally Posted by WildChild View Post
Hi,
Thank you!
On the Canadian version of the Service Bulletin it says the following, but the US one initially read that way as well and then later we received the warranty extension letters in the mail.
APPLICABLE WARRANTY
- This repair is covered under the Toyota Basic Warranty. This warranty is in effect for 36 months from the vehicle’s warranty registration date or 60,000 kilometres, whichever occurs first.
- Warranty application is limited to occurrence of the specified condition described in this bulletin.
Old 09-23-2013, 12:20 AM   #288
Hershey
Well , sounds like we may have the creaking from the front after the bolt fix . The rear suspension is creaking too . It's like having quadrophonic stereo at times . We bicker about which end it came from . Love the gas mileage , but this car has been a real pain in the in 4 1/2 years of owning it .
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 10:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 07:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
