Old 07-18-2011, 01:51 PM   #73
PROX4x4
1.5 or 2.5 both=0-60 in 8
Drives: 08 Toyota Yaris
No. Jumping 3 to 4 turns the fog lights on.
The LED needs to be connected to the illumination circuit. If you connect it to the fog light switching circuit, the LED will remain on all the time (even when the ignition is off). If you look at the attached document, which I recently put together for the MI fog light kit, it shows where to connect the LED to the connector for the lighting for the AT shift lever (the feed is present on both AT and MT cars). The green wire is + and the white is -. By using this feed for the LED, it will only light when the headlight switch is on and will dim with the other interior lights when you adjust the dimmer rheostat.
Thanks! now that makes sense, I don't know why those manuals from after market foglights call for splitting pin#3 and switching the two pieces while the other end is open?.
Can i get the illumination power from under the dash? as I am planing on installing the switch where you have installed yours.
PROX4x4 is offline   Reply With Quote
Old 07-18-2011, 02:18 PM   #74
For the LED power, under the dash you can use the dimmer rheostat connector. The light green wire is - and the brown wire is +.
Old 07-28-2011, 02:10 AM   #75
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Drives: 2007 Yaris Liftback and S13's
Thanks for all the great info and help, CTScott!!! I've been reading through this thread trying to decide which route I want to go, and you've saved me a bunch of questions and time.
Thanks for all the help over the years, YarisWorld!!!
TRD_Yaris is offline   Reply With Quote
Old 08-15-2011, 01:34 PM   #76
bambam28
Drives: Yaris Hatchback 2012 SE
can someone tell me the part number for the OEM fog light switch? thanks!
bambam28 is offline   Reply With Quote
Old 03-13-2012, 07:54 PM   #77
angelo6334
Drives: toyota yaris
Hi Im looking for the foglights to install on yaris. 2008 sedan 4 doors. Anyone knows where I can buy buy that kit thanks in advance
angelo6334 is offline   Reply With Quote
Old 03-13-2012, 08:17 PM   #78
auxmike
auxmike's Avatar
Check with Garm from Micro Image. He sells all kinds of Yaris extras.
Old 03-14-2012, 08:07 PM   #79
angelo6334
Thanks for the reply. I will check!!!
Old 07-04-2012, 11:09 AM   #80
fred_r34
Drives: toyota yaris '08 liftback
Hi to everyone. I purchased a Spyder OEM style foglights... I'm planning to do an install and i want to know where to connect the 12v switch wire... any suggestions on where can i tap from inside the cabin... I'm just going to connect the main power to the battery, fuse it using a separate atp fuseholder. My kit came with a relay and a separate on/off switch.
Any comments, suggestions and pics that can serve as a guide would be very much appreciated.
fred_r34 is offline   Reply With Quote
Old 10-06-2013, 06:30 AM   #81
adeen
Drives: 08 Toyota Vios
Hi Guyz....Sry for digging up an old post but I need some help here....
Need some insight on installing the Esuse Fog Lamp...
Ive put the blue and green wire to the yellow and white wire....it does trigger the relay when my parking light is also on.
then the green and black to the green wire (at the AT shifter) and to the ground...
im having trouble at the A24 connector since pin 1 & 2 have already been used... i've tried the other pins and nothing seems to work...
what am I doing wrong? since my lights arent working
adeen is offline   Reply With Quote
Old 10-06-2013, 06:34 AM   #82
Is your Yaris a Japanese market or European market one? If you can PM me the VIN, I can check more of the details on how fogs would get installed on your car.
Old 10-06-2013, 06:38 AM   #83
adeen
mine is from the thailand factory....asian market.....it's a vios.....thanx for the quick reply
Old 10-06-2013, 07:08 AM   #84
adeen
pm'ed u already....thnx CTscott
Old 10-06-2013, 07:22 AM   #85
OK - Got your VIN. Your car is considered a "General" area car.
From what I see there should be another connector next to the one with the green wires that is a two row connector with 12 pins. That connector would be the one where pin 1 and 2 are the fog light pins. It may be a case where the cars which come with fog lights have that connector in the harness and those that don't do not.
Old 10-06-2013, 08:25 AM   #86
adeen
here's a car with fog lights in my area...the trd sportivo version....see the difference..?
so IYO, do u think my DIY can be salvaged?
Old 10-06-2013, 08:29 AM   #87
adeen
heres a full picture of the fuse block for the version with fog lights
Old 10-06-2013, 08:42 AM   #88
I think you will need to run the feed for the lights through the firewall.
Old 10-06-2013, 09:00 AM   #89
adeen
behind the relay in the cabin theres one yellow wire, two purple wires separately and two red wires in one socket...if i locate the red wire and connect the red wire from the fog light, would that suffice? i just want the fog light indicator to light up as it should
Old 10-06-2013, 09:28 AM   #90
Using that red wire would be fine.
I actually recommend following the DIY in the link below, which I created for Micro Image instead, as the one in this thread leaves the switching and illumination circuits bridged, which results in the light on the switch being illuminated, even when the car is off.
http://microimageonline.com/forums/s...n-Instructions
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 01:18 PM
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 06:46 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Before I start calling around: fog light install prices St_G Cosmetic Modifications (Exterior/Interior) 4 03-17-2007 09:45 AM
Finally installed oem ebay fog light for hatchback Adriaan General Yaris / Vitz Discussion 6 12-27-2006 04:24 PM
