Old 10-06-2013, 10:12 AM   #91
adeen
Drives: 08 Toyota Vios
ok thx a bunch...
adeen is offline   Reply With Quote
Old 10-06-2013, 10:45 AM   #92
adeen
CTScott...what does pin 1 / pin 2 at the A24 Connector actually do? Does it trigger 12V when the fog light is on ?
Old 10-06-2013, 12:55 PM   #93
On the US market Yaris Pin 1 and 2 get fed 12V by the foglight relay when the switch is on.
On your car, that connector has a different designation than A24. I was thinking it was the same as the Japanese market Yaris, but seeing the three red wires in the position they are in, I now think your wiring is different than US and different than Japanese. I think you should measure the voltage on the pins the the locations of the 3 red wires with the fog light relay triggered on your car. I think you will find that either two of them (the two wires for the two front fog lights) or all three (which would also include the third wire for the rear fog light) will have 12 v on them.
Old 10-06-2013, 09:34 PM   #94
adeen
i've measured the green wires on the connector which gave out 0.04v when the headlights were turned on and 0v when it was off....
i've also measured the voltage on the three pins where the red wires are, and unfortunately no voltage on them...
seems like i need to work harder to get the fogs to light up....thnx for the input CTScott..
ill try opening up the fuse block and c what's underneath...
Old 10-06-2013, 09:44 PM   #95
OK. I would start from the other end (the wires leaving the fog light relay socket). The reds probably dead end at one of the junction connectors under the top of the dash.
Old 10-06-2013, 09:54 PM   #96
adeen
ok....i'll get to it as soon as i've got time to spare....i'll update any progress...
Old 10-11-2013, 09:55 AM   #97
adeen
i had my wire go through the firewall and connected it directly to the #3 pin of the foglight relay. works like a charm...thnx CTScott
Old 02-03-2014, 10:30 AM   #98
bairjo
For what it is worth, I threw together a video of my fog light install using the OEM light stalk. Hope I didn't leave anything out. It moves along rather fast at the beginning as I needed to keep it under 15 minutes for YouTube. Thanks go out as usual to CTScott for his in depth contributions on this mod as well as others he has come up with. Hope the link works.
https://www.youtube.com/watch?v=bilhPerqVEo
Old 02-03-2014, 11:03 AM   #99
auxmike
auxmike's Avatar
Bairjo, you knocked it out the park, man! Fantastic job and even the music is good here!
Old 02-03-2014, 05:57 PM   #100
bairjo
Thanks Mike...I never know how well received some of my videos will be. Hope it helps others out when they do thier install....thanks again.
Old 02-03-2014, 06:09 PM   #101
auxmike
auxmike's Avatar
I priced the stalk at 95USD. Does that sound right?
Old 02-03-2014, 06:42 PM   #102
$91 is about the cheapest I have seen the OEM stalk go for. On all of mine, I used an illuminated switch that I mounted to the dash. It is the same one as well that is included in the Micro Image kit. If you want to save some money, I can ship you one for $10.
By the way, Bairjo, nice job with the video!
Old 02-03-2014, 06:46 PM   #103
auxmike
auxmike's Avatar
That's nice. Can you PM me paypal info? I'd like one..
Old 02-03-2014, 06:49 PM   #104
auxmike
auxmike's Avatar
Also, can you tell me how I'd get it to light up? My current switch is between the seats but I can't figure out how the heck to get the light to work. The best I got was the light being constantly on ...
Old 02-03-2014, 07:43 PM   #105
The problem with the one that comes with the aftermarket kits is that the switching and illumination are tied together. To use the switch with the OEM wiring you have to separate the two by snipping one of the resistors off the circuit board within the switch.
The one that I use has separate wiring for switching and illumination, so you will have to connect 4 wires to hook it up. Two go to two wires on the headlight switch connector and the other two to two wires on the connector for the dimmer rheostat.
Old 02-03-2014, 08:23 PM   #106
bairjo
Well I was trying to upload photo copies of the directions out of the Toyota shop manual on how to properly adjust the fog lights but failed due to a "missing security token" whatever that means. Anyhow, I have not seen anything on the topic of adjustment. I'm having a little difficulty dialing one in to the proper height. Anyone care to share how you did your fog light adjustment and how did it go? By the way, my light stalk was $87 + 10 shipping. That arrangement CTScott has looks real slick....much better than the switch between the seats set-up. I had my switch between the seats on my 08 and really didn't care for it.
Old 02-03-2014, 08:37 PM   #107
With the foglights that have the adjustment mechanism that points down towards the ground, you stick a phillips screwdriver up in there and tighten to raise, and loosen to lower. I cranked mine way down to where the light patten starts right where I can see past the hood.
Old 02-03-2014, 08:52 PM   #108
bairjo
Thank you. That sounds a heck of a lot easier than how Toyota spells it out. I have measured out lines taped on the wall trying to hit the mark...I'll go with the CTScott plan!
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 01:18 PM
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 06:46 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Before I start calling around: fog light install prices St_G Cosmetic Modifications (Exterior/Interior) 4 03-17-2007 09:45 AM
Finally installed oem ebay fog light for hatchback Adriaan General Yaris / Vitz Discussion 6 12-27-2006 04:24 PM
