Old 10-07-2013, 05:25 AM   #127
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
.032 to .029.
I would go as low as .022
-Derrick-
Old 10-07-2013, 03:06 PM   #128
thatbryanguy
Drives: Yaris 3dr hatch
.032 to .029.
I'm not sure I'm going to mess with the gap anymore because I'm 90% sure it has to do with the FIC itself just because when the FIC is bypassed the car doesn't misfire at all. So I figured as long as the car is getting the signal to spark, it does and doesn't have a problem igniting the mixture without the FIC.
thatbryanguy is offline   Reply With Quote
Old 10-07-2013, 03:18 PM   #129
ilikerice
ilikerice's Avatar
I hear ya. And you're probably right. I was just suggesting what gap I set mine. My crx had issues with loosing power at full boost. Is wasn't at bad when I went .033 and eliminated the issue completely at .022.
I am not saying this is the problem with your car. I am just adding my experience and what I set my gap when I was boosted.
-Derrick-
Old 10-07-2013, 07:17 PM   #130
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Originally Posted by thatbryanguy View Post
Awesome Scott, I didn't know that about checking grounds. I guess I'll use that method to check as much as I can. As far as plug gap I re-gapped down from .032 to .029.
I'm almost positive it has something to do with the ECU fighting the FIC or something like that but I have very limited knowledge on how the FIC works and how the ECU responds. I just don't see it being an existing issue with my car since the car runs smooth and fine even at idle when the FIC is bypassed.
you mentioned a gas smell. make sure the injector cushions are seated properly or you will have misfire. Do you have a lightweight flywheel? that will cause false misfire codes.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 10-07-2013, 08:46 PM   #131
thatbryanguy
@blown_xa, I do have a lightweight flywheel but you can hear and feel when it misfires so I don't think its a false code unless it's just idling rough for some other reason and the misfire code is just a coincidence
@ilikerice, no I get ya, that's why I did try closing the gap a bit but it just seems more like the problem is from another area. I also don't have any problems with misfiring when I'm giving it gas or hitting boost, it's only when I let go of the gas and idle or put it in neutral that you hear and feel it misfiring.
Old 10-07-2013, 10:22 PM   #132
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Try zero's yet in the lower RPM range yet? Sounds like its too rich at idle
Old 10-08-2013, 01:57 PM   #133
thatbryanguy
Haven't gotten to a PC yet but that is definitely one of my first things I'll try then I'll try all the different firmwares.
My brother is helping me put together a junk PC tower tonight with a bunch of his random spare parts to use. I'll post with the results of the change as soon as I get that all done.
Old 10-17-2013, 09:11 PM   #134
thatbryanguy
I finally got an old laptop to use to change my cal file on my FIC. So when I go to modify the fuel map on the cal file, what boxes should I make 0 for the lower rpms? I'm completely unfamiliar with how this works.
The car runs fines with a completely zero'ed out map (the base cal file) so I just need to know how exactly the FIC picks what boxes at idle. I see the rpms across the top but on the left it says psi so I'm not sure what to change.
Old 10-25-2013, 11:50 AM   #135
thatbryanguy
Update: Put in zeros for the boxes the FIC uses for idle and it helped a little it seemed with the roughness but it still stalls out at idle.
Old 08-14-2015, 09:22 PM   #136
Bluevitz-rs
Bump for reference....
FS: AEM FIC + Wiring Harness Boomslang djgab101 Items for Sale by private party 18 12-06-2013 04:36 AM
FS: Zage Turbo kit, AEM FIC with Pnp Harness djgab101 Items for Sale by private party 32 04-11-2013 11:42 AM
AEM FIC tuning experience thatbryanguy Performance Modifications 0 09-03-2012 02:29 PM
AEM FIC to replace CamCon cc101 ?? vten Forced Induction Forum 26 08-04-2012 08:38 AM
AEM FIC works perfectly cdydjded Performance Modifications 58 08-03-2009 07:20 AM
