![]() Drives: 2008 Sedan Join Date: Sep 2013
'08 Cruise control not working
First time poster, be gentle please
![]() I have an australian '08 model Yaris, and have just tried to install a Rostra cruise control, unfortunately it does not seem to want to work. After some research I quickly found that it was not possible to do the easy install on the australian model of Yaris, by just adding the control stalk. I took the chance on the ECM etc being roughly the same on the '07 and '08 models and bought a Rostra 250-1873 kit to fit an '06-'07 Yaris. The install went smoothly with the wiring and connectors being the exactly the same as supplied, and pictured in the documentation. Took it for a test drive, light comes on, but acc/decel does not work. Anybody got an idea whether the 06-07 Rostra CC should work on the '08 model car? Are there any known differences between the ECM's on the 06/07 and 08 cars? Any other advice (constructive) will be appreciated. TIA Regards, Graeme |
The Rostra kits are harder to diagnose than the OEM cruise control is. I would start with the VSS (vehicle speed sensor) connection, making sure that is is properly crimped on the wire and making a good connection.
Thanks so much for the reply, and indication of what to look at.
Will get in and check that out as soon as I can get to it. Just for clarification. Can you see any particular reason why the '07 model CC unit will not work in an '08 model car? |
No. The 250-1873 kit would actually work on 06-11 AUS market Yaris.
Drives: Toyota Yaris 2007 NCP90R Join Date: Sep 2018
Hi Guys,
I bought the same 250 1873 for my Yaris 2007 3DR hatch and i have the same issue. The led comes up but it doesn't keep the speed for some reason. I even did all; troubleshooting provided by rostra in the guide and all comes okay. Any advice ? @OhSevenOhSix Did your started working ? |
| Tags |
| cruise control, electrical, yaris 2008 |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 04:45 PM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 04:43 AM |
| Rostra 250-1731 cruise control kit for Yaris | PeetYaris | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 06-26-2011 07:48 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 04:55 PM |
