Old 11-05-2013, 04:11 AM   #1
SilverSquash!
Stage ...Base
SilverSquash!'s Avatar
Drives: Toyota Yaris LB '07
1.0 exhaust branch v cat...lambda problems
Hi people. I have a 1.0 2nd gen yaris with the 1kr-fe engine. The cat is apparently shot and should be replaced however i thought shouldn't replacing it with a branch be better. However there are two lambda sensors i need to get through, one is at the top of the cat and the other below the cat. Is there any way to bypass these sensors in order for me to the branch and not get an engine warning light/any warning light for that matter?
Your responses are much appreciated!
2007 Toyota Yaris T1-2 Door
Stinger Roadkill//Lamin-X Smoke//Sony HU//35% Smash & Grab//Colour Coded//Spoiler//Fog lights//Vinyl Eyelids//Non-Slip Matting
SilverSquash! is offline   Reply With Quote
Old 11-09-2013, 12:24 AM   #2
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Space out the 2nd o2 sensor with a spacer from vibrant performance
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 11-16-2013, 02:55 AM   #3
SilverSquash!
Stage ...Base
Thank you very much! I'll have a look into that:)
Tags
1kr-fe, exhaust, lambda
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 09:02 AM
Exhaust manifold heat shield Problems. Help!! MaXx0909 DIY / Maintenance / Service 5 07-29-2013 11:30 PM
Enkei's and Dunlops + Medalion Touring Exhaust 2manywheels Items for Sale by private party 40 04-04-2011 06:01 PM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 10:23 PM
