Old 11-30-2013, 08:05 PM   #1
fybur
fybur
fybur's Avatar
Drives: 2013 Yaris L A/T Magnetic Grey
Rear Brakes Worn Down
I took my car in for its 5k service and the technician checked my brakes. For the front both sides are at 10mm (which is awesome according to this form) but the back two are on 3mm (meaning I will need them replaced).
Yes I do drive my car in a "spirited" manner. I rarely brake hard or for long periods of time while driving. I got this car brand new on June 12.
Can someone explain why the back is so much lower than the front? Is it due to the difference in brake type?
fybur is offline   Reply With Quote
Old 11-30-2013, 08:06 PM   #2
Rear shoes are extremely thin to begin with. Only ~4mm new. They rarely need replacing. Hence the reason why there has yet to be a DIY published on replacing the rear brakes.
Old 11-30-2013, 08:09 PM   #3
fybur
fybur
fybur's Avatar
Great I was set up to fail.
Old 11-30-2013, 08:13 PM   #4
Yep.
Old 11-30-2013, 08:17 PM   #5
fybur
fybur
fybur's Avatar
Any good brand to replace them with? Or should I just do a conversion?
Old 11-30-2013, 08:23 PM   #6
Why do you want to replace them? They are barely worn.
Old 11-30-2013, 08:24 PM   #7
fybur
fybur
fybur's Avatar
No no not right now. Later when they need replacing.
Old 11-30-2013, 08:30 PM   #8
So like 7 or 8 years from now. Mine has been on the road for 8 years, 200,000 kms, and I'm at 1.5 - 2mm.
Old 11-30-2013, 08:35 PM   #9
fybur
fybur
fybur's Avatar
Damn, they last that long. Ok then not worried about them failing in a year or two.
Old 12-02-2013, 09:43 AM   #10
IllusionX
Drives: 07 Yaris Sedan Aero
Mine's 7 years at 137000k, and have a good 1.5mm left. I've been doing alot of stop and go and handbrake alot in the winter. hehe
Old 12-08-2013, 11:31 PM   #11
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Just keep them adjusted properly,that way you won't fatigue the front so quickly.
frog13 is offline   Reply With Quote
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 11:11 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-06-2008 12:37 AM
