#199 |
That is because you did not follow the instructions. You connected the wrong side of the brown wire to the white wire. You need to cap off the end that comes out of the connector and instead tap the end that heads up to the cluster to the white.
#200 |
![]() Drives: 2008 Yaris Join Date: Jun 2013
Oops, I got it totally opposite. My wife is driving the car today, will fix it tomorrow.
Thank you very much CTScott |
#201 |
![]() Drives: 2008 Yaris hatchback in white Join Date: Apr 2012
I was just studying this TPMS sensor solution. Comparing photo #2 the the color coded diagrams, it looks like one just clips the brown wire and splices it to the white one, and that this would be easy using one of those press down splicers, and of course taping off the end of the other brown wire.
Please let me know if this interpretation is correct. Or if anyone has a picture of the completed splice please post. Since this is reversible it looks like an easy solution. Thanks, Maui |
#202 |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
Will this work if you have a bad TPMS? My light flashes and stays on.
I'd rather disable it all together, stupid shop wants $320 |
#203 |
Yes it would make the light go away.
#204 |
I did this over the weekend when i had my tires replaced. I had them pull the sensors out too. Worked like a charm. Thanks guys
#205 |
Drives: Yaris (2010, 2007) Join Date: Jul 2016
I did this fix on a 2010 Yaris and it worked perfectly, so thanks a lot! But now I want to do the same on a 2014 Yaris (4 door hatchback) but I don't see the TPMS ECU behind the glove box. Does anyone know where it is? I couldn't find any free repair manuals online like there are for older models, cheapest one on eBay is $60...
#206 | |
The third gens do allow you to easily relearn the TPMS sensors by simply pressing a button, so the simplest solution is to have a second set of sensors in your alternate rims.
#207 |
![]() ![]() ![]() Drives: 2006 Yaris RS 3-Door Join Date: Feb 2016
Is there not a way to short out something at the wheel/sensor end before it gets encoded onto the CAN buss?
This looks like yet another case of unnecessary electronic complexity being put into cars, which means more things to go wrong. I work in the very high tech semiconductor/software industry myself, so I'm not against advances in technology as such, just against technology which causes more problems in the long run. Sent from my LG G2 with CM13 using Tapatalk Last edited by tarkus; 12-05-2016 at 12:56 PM. |
#208 |
![]() ![]() Drives: '08 HB Join Date: Nov 2008
Just did this mod
Cut the brown, press-splicer brown and white....worked perfect (after I plugged the connector back into the box - duhhhh).... Thank you - this place rocks! (I chose to not have the sensor replaced after I heard it bouncing around in the left front tire and would have to pay $60 for a replacement) |
#209 |
Drives: Yaris sedan 2010 Join Date: Jul 2017
Hello friend, let's see if you can help me! I have a 2010 Yaris sedan and I changed my tin rims for type S, I did not change the TPMS sensors of my original rims but the emergency rubber still has the factory sensor. The type S rings have their original TPMS sensors but the vehicle that had them. How can I configure the new sensors in my vehicle?
I know it's not a blog but I hope I can help. Grateful!!! Enviado desde mi SM-N910W8 mediante Tapatalk |
#210 |
![]() Drives: 2010 hatch Join Date: Aug 2017
Sorry. I didn't read through the hundreds of posts. Just skimmed through and I didn't see that anyone had done what I did on my "09 Tacoma and '10 Yaris.
I removed the instrument cluster. It's very simple and just placed a double folded portion of electrical taped under the gauge face plastic film. Done. This way nothing is eliminated if years from now you or the next owner wants the system in use. It looks like the light was never there. |
#211 |
![]() ![]() Drives: . Join Date: Mar 2019
My apologies for resurrecting an old thread but I am having a problem with my TPMS on a 2011 Yaris.
The problem is, all of the pictures posted were on PhotoBucket and they purged all of their free user pictures. The only pics lift are of Rick's on post #138. I can happily try this one but I'd like verification that it worked from someone. Also, would disabling the TPMS show up in the OBD2 scan? thanks! |
#212 | |
![]() Drives: Yaris hatch Join Date: Jun 2021
TPWS issue
Can someone suggest a way to get the idiot light off AND disable the TPWS system please? |
#213 |
![]() Drives: Yaris Seden 2008 Join Date: Apr 2013
post #115 picture on the left will do it
#214 |
![]() ![]() Drives: Toyota Yaris 2015 1.0VVT-i T2 Join Date: Jun 2012
Does this work on a 2016 Yaris?
Toyota Yaris 1.0VVT-i T2
#215 |
![]() Drives: 2013 Yaris Join Date: Jul 2025
I have a 2013 Yaris, anyone please tell me how to disable this abomination system lol. thanks
#216 |
HELP LOL
| Tire pressure sensors | Tink1 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 10-21-2008 06:53 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 11:07 PM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 08:09 PM |
