![]() ![]() Drives: 2009 Yaris HB Join Date: Sep 2013
Options and opinions?
Hey everyone so I have been going through the local CL and these are my current options.
They range from used to new, 15",16",17" I am trying to figure out which way to go with these. I'm ok with used and they don't have to be the best looking as I am not trying to turn the YARIS into a show car, just thought I'd upgrade the rims while I needed to get new rubber. I plan to plastidip the rims black and get red rim tape anyways unless they are new. Please let me know what you think 1) $190 Black miata compatable rims http://vancouver.en.craigslist.ca/va...319484870.html 2) $300 Acura wheels 15" with tires 4x100 http://vancouver.en.craigslist.ca/rd...273075577.html 3) $300 16" Momo Rims with mounted Toyo Tires http://vancouver.en.craigslist.ca/rd...305843974.html 4) $600 plus tax 17" 4x100 FRD Alloy wheels with 205/40R17 Special Buy! http://vancouver.en.craigslist.ca/rd...311909134.html 5) same company as above and but $700 plus tax for 16" set ($100 more) |
Hard to say, since I know nothing about your car. Color? Lowered?
The Acura rims are just horrible. The Momos don't say 4x100 and the tire size is not quite right for the yaris. But I like the look. Can't tell about the 17s'. You'll sacrifice some ride quality and they might be heavy (dont' know the weight).
Out of those indicated, definitely the Momos if they are 4x100. Yes the tire size is not ideal. The sidewalls are a little short. 195/50 is a nice size on 16s.
All the other options
OH sorry my Yaris is a metalic white 2009 HB 4door stock. 14 inch steel rims.
The momo's might not be the right size? they say "Momo Rims x4 Size 16" (4 bolt pattern)" so i thought they would fit |
There is the possibility that the momos are 4x114.3 and would not fit.
The 100 or 114.3 is the distance between studs.
WeeYari - thanks for your input. If the momo's don't fit I may go for the black miata ones. Once again I'm not trying to pimp out the yaris, just would like rims as I hate the steel rims.
If you end up contacting the seller to verify the 4x??? question, also ask what the offset of the wheels are. There should be a number stamped on the back side. This would be a 2 digit number probably in the range of 40 something to 30 something.
#8 | |
![]() He just emailed back saying they should fit as I told him it was a yaris and that these rims came off his acura. |
He just checked and the MOMOs are ET35 will this be an issue on tires he has now? This is outside the offset recommended on the wheel guide on this site
Toyo Proxes4 x4 Size 205/40ZR16 83W |
Like the momo also 17 look nice ...I would stick with 16 max
Yeah I like the 17s too. They can do 16s in a few different styles with tires, all new but they would want 699 plus tax (all in mounted balanced and out the door)
The momo are "ET35" and tire size is 205/40r16 I can't find a match in the wheel gude page. I am still concerned this will cause problems with my stock suspension? ?? This also just got posted but i dont know if 205/50r16 is too big for stock setup http://vancouver.en.craigslist.ca/rd...309665736.html Last edited by rcvmini; 02-06-2014 at 08:59 AM. |
No, you will be fine. With the short tires tho, your wheel gap is going to be big enough to stuff a football into.
I'd check out the "Miata" wheels.
#14 |
Thanks everyone,
Looks like I'm going to check out the momo rims this saturday. Wee Yari - if I lower the car with springs I take it that would reduce the gap and make the tires fit better? saw some springs that would lower the car 1.5 inches These springs here seems to have good reviews. LoTek and M2 http://www.ebay.com/itm/4-NEW-Lotek-...16b28f&vxp=mtr kimona - seconed option is to have a look at the 'miata' ones but he is further away then I thought * btw nice avitar - i'm going to get an outfit like that for the wife ! Last edited by rcvmini; 02-06-2014 at 08:15 PM. |
#15 |
for this price, i would catch it when the microimage springs go on sale. I bought mine for 99$.. obviously plus shipping
#16 |
Dropping 1.5" should leave you with a sloppy two finger gap unless you have sausage fingers, in which case it would be a tight two finger gab.
ET35 + 205 tires may mean that you will experience mild buzzing in the rear as the tires rub against the fender liner going over hard dips or with a load of passengers and stuff. One of my sets of wheels was 16" ET42 clad with 195/50 tires. These were coupled with 10mm spacers giving me an effective offset of 32. The rear right would rub. Had to introduce mild camber washers to tip the top of the wheel inward enough to totally clear the liner.
#17 | |
#18 |
^ Sorry, that is correct. I was envisioning a liner, but that is only in the lower rear portion of the wheel well. So yes, the rub will occur in the fender lip at the top of the arch.
| I NEED Boost... Opinions puh-lease | Focus_Sh1ft | Forced Induction Forum | 551 | 02-08-2013 05:55 PM |
| Sway bar opinions | Nelson | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 24 | 12-10-2008 06:40 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
| Need Opinions on Package Options | bdc87 | New YARIS Purchase Forum | 8 | 06-26-2007 01:55 PM |
| Opinions on '07 Hyundai Accent hatch? | Yaris Revenge | Off-topic / Other Cars / Everything else Discussions | 44 | 05-07-2007 11:18 PM |
