Old 02-17-2014, 05:20 AM   #1
nerdyguy
Drives: 08 yaris
16" rims
I have a 2008 yaris hatchback and I'm looking to get new rims in size 16. What is the best size and offset for 16's? I want it to look flush with the fenders, I do not plan on having any fender work done. Also, does anyone have pics of a 16x8 +25 on their yaris? Thanks.
nerdyguy is offline   Reply With Quote
Old 02-17-2014, 12:08 PM   #2
G-Ammo
G-Ammo's Avatar
Drives: Toyota Yaris 2009; 1.0 3 Cil.
16x8+25 should be ok!
I have 15x7 ET20 and the front is just underneath the fenders (with 185/40/15 tyres)
So the one you said should fit almost the same! (I used some spacers in the rear to let the rear pop out a bit :D)
Speedbumps suck...!
G-Ammo is offline   Reply With Quote
Old 02-18-2014, 08:25 AM   #3
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
this ^^^
16x8 +25 is a good size to be flush with the fenders. However I would recommend going with a wider wheel and a higher offset to allow a bigger tire stretch. 195 is about as thin as you want to go and if you stretch that on an 8" wheel its pretty chunky and could still rub. a 16x9 +35 or so would give you about the exact same effective sizing as 16x8 +25 but would give you more stretch to really clear the fenders since you wont be doing any fender work. 195 on a 9 is beyond a safe stretch lol I daily 205/40 on 10 with 0 issues
Old 02-18-2014, 09:32 AM   #4
I run 16x7 +45 European Toyota TTE Pitlane wheels on my 09 with 205/50/16 tires.
Old 02-18-2014, 11:11 AM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
I really should have had a moonroof done on my Yaris.
Old 02-18-2014, 11:55 AM   #6
Yaristeve
Drives: 3-door hatch
Nice. Is it lowered?
Old 02-18-2014, 12:04 PM   #7
kimona
kimona's Avatar
Drives: 2014 White VITZ
I'm running 16 x 7, ET42 with 205/50/16 on my '07. I'm flush up front.
Old 02-18-2014, 01:10 PM   #8
No. Stock suspension.
Old 02-18-2014, 03:55 PM   #9
Yaristeve
Hmmmm... With a +45mm et, I suppose there should be no fender rubbing problems if lowered...
I assume no rubbing on the inside wells when turning?
Old 02-18-2014, 04:59 PM   #10
No rubbing. Toyota specs them for 195 width tires, so lowered 205's might rub.
YOUR OFFER>.. Price You Want: OEM SPRING, EXHAUST, HEADER, EQUIP 03 16" rims neo1985 Items for Sale by private party 15 09-14-2009 10:01 PM
16" OEM Vitz Rims regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-12-2009 09:01 AM
which size tires for 16" rims? tekmoe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 01-28-2007 07:12 PM
