![]() Drives: 08 yaris Join Date: Jul 2013
16" rims
I have a 2008 yaris hatchback and I'm looking to get new rims in size 16. What is the best size and offset for 16's? I want it to look flush with the fenders, I do not plan on having any fender work done. Also, does anyone have pics of a 16x8 +25 on their yaris? Thanks.
![]() ![]() ![]() Drives: Toyota Yaris 2009; 1.0 3 Cil. Join Date: Oct 2010
16x8+25 should be ok!
I have 15x7 ET20 and the front is just underneath the fenders (with 185/40/15 tyres) So the one you said should fit almost the same! (I used some spacers in the rear to let the rear pop out a bit :D)
Speedbumps suck...!
Form>Function
this ^^^
16x8 +25 is a good size to be flush with the fenders. However I would recommend going with a wider wheel and a higher offset to allow a bigger tire stretch. 195 is about as thin as you want to go and if you stretch that on an 8" wheel its pretty chunky and could still rub. a 16x9 +35 or so would give you about the exact same effective sizing as 16x8 +25 but would give you more stretch to really clear the fenders since you wont be doing any fender work. 195 on a 9 is beyond a safe stretch lol I daily 205/40 on 10 with 0 issues |
I run 16x7 +45 European Toyota TTE Pitlane wheels on my 09 with 205/50/16 tires.
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
I'm running 16 x 7, ET42 with 205/50/16 on my '07. I'm flush up front.
No rubbing. Toyota specs them for 195 width tires, so lowered 205's might rub.
| YOUR OFFER>.. Price You Want: OEM SPRING, EXHAUST, HEADER, EQUIP 03 16" rims | neo1985 | Items for Sale by private party | 15 | 09-14-2009 11:01 PM |
| 16" OEM Vitz Rims | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 04-12-2009 10:01 AM |
| which size tires for 16" rims? | tekmoe | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 01-28-2007 08:12 PM |
