Old 03-03-2014, 02:08 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Deatschwerks Fuel Injector Service Review
I have a set of Scion Tc injectors that I picked up. Since they could vary between 330-370cc and they have been sitting for a while so I decided to get them flow tested and serviced. I chose Deatschwerks as I have received solid input from several folks about them. They charge 20 bucks per injector for their Dynamic Service.
deatschwerks injector services
I am shipping them today and will let you know how it seems to go.
Old 03-07-2014, 09:29 AM   #2
fnkngrv
fnkngrv's Avatar
Got the call yesterday and they are all wrapped up. Ended up being 335cc avg. Once I get them back I will post up the results sheet. These may be ok for a street tune, but not the LSRs so I will need to pick up a set of 800-1000cc injectors. I know my current 1zz injectors are 240cc and I am maxing them out at 5200 rpm already at the 210/210 point on vp100. 190/190 on pump.
Old 03-08-2014, 04:39 PM   #3
kou
Drives: 08 lb
Don't go 800-1000cc they are to big I would say some 440cc should be fine plus if you have raised the fuel pressure they will be flowing more. I am running 440cc injectors with a 58psi/4bar fpr and the injectors are flowing 508cc. I may switch out my fpr for a 3bar/43.5psi fpr because my fpr is rising 1:1. I am running an AEM 300lph fuel pump 5.0motorsport 440cc injectors and a blowerworks fpr all on a return fuel system handling 10psi richly.
Old 03-10-2014, 02:33 AM   #4
I ran 635cc injectors at 24psi. Never even approached max duty cycle, and idle was a little rough. You'll be in trouble with 800+.
Old 03-10-2014, 11:56 AM   #5
fnkngrv
fnkngrv's Avatar
Alright. Good to know. Thanks guys.
Old 03-12-2014, 10:44 PM   #6
fnkngrv
fnkngrv's Avatar
Looking like I will go with the ID725 set since they most closely match my future needs.
Old 03-12-2014, 10:47 PM   #7
fnkngrv
fnkngrv's Avatar
I should be able to post up the results sheet by tomorrow evening. The package is sitting at home and I am stuck 200 miles away due to storm Vulcan.
Old 03-14-2014, 01:15 PM   #8
fnkngrv
fnkngrv's Avatar
I received my injectors back from Deatschwerks while I was away on business travel. Here you will see that they professionally pack the injectors after the service and provide an installation lube. They gave me a call prior to charging my card which was a nice touch to also confirm as well that the shipping address had not changed. They were pleasant and knowledgeable on the phone while speaking with them.
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-03-2026 12:44 AM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 04:34 AM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 03:35 PM
