Old 03-06-2014, 07:07 PM   #1
Revengeance
Drives: 2000 Toyota Vitz (scp10)
Rubbing issues..
Hi guys... I've already read the tire and wheel guide but im still confuse on rubbing issues..
2000 toyota vitz (echo) scp10
Tein high tech springs
205/40r17 8j +40 offset (it rubs alot)
I was planning to to change it to a
195/50r15 6.5j +38 offset
Will this still rub?
I appreaciate any information and help..
Thanks..
Revengeance is offline   Reply With Quote
Old 03-07-2014, 12:40 AM   #2
You'll have 21mm more clearance on the inside, and 17mm on the outside, so that should most likely eliminate all rubbing.
Old 03-07-2014, 02:16 AM   #3
Revengeance
Thanks man i love you!
Btw, how did you know the exact mm inside out?
Old 03-07-2014, 02:32 AM   #4
Just a guess. haha. jk. I used this site:
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
Old 03-09-2014, 04:44 PM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
the 8" rim is what's causing the rub issues. Going down to the 6.5 and a 195 should solve everything.
Rubbing Issues RacerFreakXXX Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 05-12-2010 09:26 PM
any rubbing issues with stock height and... severous01 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 03-15-2010 02:22 PM
anyone rubbing with df210 on 205/45/17 marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-09-2009 11:59 AM
Rubbing: 185/60/15 w/NF210's songa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 12-10-2008 06:09 PM
