Yargatti
So I have a 2010 Sedan with 15x8 +25 rims with LoTek drop springs. I've rolled the fenders but when I hit a bump or have multiple people in the car it scrapes. I have Camber bolts on the front, but how do you camber the rear? I heard of shims but where do you put them exactly?
They go between the brake drum and the axle hub.
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
Between the brake drum and the hub would make for a clown car ride (Wobble, wobble, wobble). The spacers go between the axle beam and the hub. Last edited by Flipper_1938; 03-24-2014 at 08:42 AM. |
やりすぎだ~
See this thread to better understand it. But in the OP's case you'd either have hub spacers that are tapered - skinnier on the top, or some place washers on the bottom two bolts.
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
realcamber.com makes -3 or -5 degree shims. He makes them for Scion XB/XD and Yaris/Prius. Just like Sugi said they install identically to the hub spacers in that link, that is the link I used to install mine as a guide. They are thinner on the top and thicker on the bottom. The Fab work is perfect and ive ran mine for about a 14 months or more without issue. The seller will include studs to use and provides even longer ones if you plan to run a hub spacer in addition. Remember these are fixed so chose your size wisely as they are very expensive for what you're getting. Also being that this is just a slash cut spacer you will be adding some negative effective offset so dont forget to account for that.
![]() ![]() Drives: White Yaris Sedan Join Date: Mar 2014
What are some good front/rear camber kits specifically front? All I see are camber kits that just come with bolts; is there more to it? Thanks.
Form>Function
Up front you only use the camber bolts, top hole only on each side maxes out at 1.5-2. Both holes on each side maxes out around 3ish IIRC. Rear your only options are to cut and weld your axle or shims.
#8 | |
![]() ![]() Drives: white yaris hatchback. Join Date: May 2011
http://www.instagram.com/dino_eggxo |
Form>Function
yes the dude is a great craftsman and the shims have a toe correct built in, ive never aligned my car with the shims but my tire wear is really impressive for -6 degrees so I know my toe isnt bad
![]() ![]() Drives: 04.:R32, 87 Scirocco, 07 yaris Join Date: Apr 2009
Daaaaamn 160$ haha...
Something else to save for |
Form>Function
yea lol for just some slash cut spacers but hey... gott pay to play lol
![]() ![]() Drives: 07 yaris 3dr Join Date: Aug 2013
Anywhere else to get them? He's all sold out..
Sent from my iPhone using Tapatalk |
![]() Drives: Toyota Yaris Sedan Join Date: Apr 2013
#14 |
![]() ![]() ![]() Drives: 2008 lowered yaris on 17's Join Date: Feb 2015
Anyone know how to get in contact with this guy? I NEED camber.
| Could the 07-08 yaris s front lips actually fits 2010 yaris? | Adward10 | Cosmetic Modifications (Exterior/Interior) | 3 | 03-18-2013 12:06 AM |
