Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
ABS light, no Code
ABS light keeps coming on, I assume it has something to do with the light weight flywheel.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
Does it come on and then quickly go off, or does it say on until you kill and restart the car?
twice it came on right after starting and driving but went off before i left the parking garage, and another time i was in traffic and it stayed on for a little while and then went out. Fluid is full, no signs of leaks.
Mr. 155 and climbing
I ran into that a couple years back and it ended up being the sensors. Toyota replaced them.
^ That would be my bet as well. I would check the connectors on the rear sensors, as they are very prone to corrosion. If you catch it early enough you can clean and seal the connectors.
I will have to look into that. Only 52k miles on the car, and no driving in northern salty areas.
VSS on the passenger's side. the bolt had backed out so the sensor would occasionally wiggle back in its hole. new bolt and torqued, problem should be solved.
| OFFICIAL Yaris SEDAN thread | SimmZ | Photo-Video-Media Gallery | 1706 | 06-22-2025 05:33 AM |
| Sponsors List | RogueYaris | Sponsors Classifieds Area | 14 | 01-05-2013 10:23 PM |
| Brake & ABS Light On | JeffRapp | DIY / Maintenance / Service | 3 | 01-04-2013 11:10 PM |
| Sharing and Need Help! Lowered but abs light came on! | tobymak21 | California | 0 | 08-08-2012 08:48 PM |
