Old 05-13-2012, 09:30 PM   #19
carolinablue
Drives: 2012
The width of a 2011 Yaris 3 door lift back is 66.7 inches as is the width of a 2012. The width of the five door is the same as the 3 door for both years.
carolinablue is offline   Reply With Quote
Old 05-14-2012, 12:25 PM   #20
auxmike
auxmike's Avatar
I have this on my '08 hatch. It firms up the rear real nice. I paid $152 in '08 so the price has remained fairly stable.
Old 03-04-2014, 11:23 PM   #21
2012yarisowner
Drives: 2012 Yaris sedan
I wanted to ask is the 2012 sedan the same as the 07-08 sedans, wanted to get the rear sway bar put on but the dealer said it wouldn't fit correctly so figured i'd ask to see if anyone knows if it would work on the sedan?
2012yarisowner is offline   Reply With Quote
Old 03-05-2014, 12:29 AM   #22
MyzticZ3r0
Drives: 2007 Toyota Yaris Hatchback
The 22mm whiteline sway bar is what you're looking for:
http://shop.microimageonline.com/Whi...-xD-BTR86Z.htm
MyzticZ3r0 is offline   Reply With Quote
Old 03-05-2014, 12:43 AM   #23
2012yarisowner
Thanks for the help
Old 03-27-2014, 11:52 AM   #24
scmoky
Drives: Yaris 2012
How thick is the TRD rear sway bar? 19mm or 22mm? I also look for TRD springs for Yaris III, but didn't found anything, could you give me a link please.
Regards
scmoky is offline   Reply With Quote
Old 03-28-2014, 10:26 AM   #25
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
Regards
If you are upgrading the springs, then there is no need for the 22mm bar.
The TRD 19mm is just right.
For the TRD springs, many have not updated their catalog, do a search for 2011 yards. They work, I have a set installed.
Go here, good people:
http://www.trdsparks.com/displaypart...&parts_id=1374
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 03-30-2014, 12:37 PM   #26
scmoky
Drives: Yaris 2012
Thanks, Just one little offtopic. TDR sadly not avilable in Europe. So Eibach Pro kit(same as TRD) or H&R?
Old 03-30-2014, 09:33 PM   #27
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
whichever you prefer, depending on spring rates. Both are good names.
Colin Chapman disciple
Old 03-31-2014, 06:18 AM   #28
boooggy
Drives: 2014 Yaris lb 1.33L
u can order via ebay
only that you have to pay transport and import taxes....
boooggy is offline   Reply With Quote
Old 10-01-2014, 02:43 PM   #29
roxy1
Drives: 2014 yaris 5 speed
got this installed today and it does everything folks here claim it to do. however, I could hear some metallic rattling on my dirt drive. it is noticeable that the bar tucks farther up into the torsion beam on the right side than the left...close enough that it may be causing the rattling. either the bar is bent slightly at one of the curves or my torsion beam is crooked.
looking at tooters pics at the beginning of the thread, his bar seems equally tucked into the beam on both the left and right sides. I suspect the bar is off. my shipment got pushed back a day on the day it was supposed to arrive. makes me wonder if there was an "incident" with the package.
roxy1 is offline   Reply With Quote
Old 10-01-2014, 03:11 PM   #30
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
roxy, I had a similar problem like yours - sway bar bumping against the beam. I loosened both bolts and pulled the bar down a bit to prevent contact then tightened the bolts back up and it's been trouble-free since. You might have to hold the bar down a little whilst tightening the bolts.
Old 10-01-2014, 03:15 PM   #31
IllusionX
Drives: 07 Yaris Sedan Aero
It says in the instructions that the bar should not touch anything beside the mounting points!
Old 10-01-2014, 03:30 PM   #32
roxy1
yes, i will be doing this later today.
Old 10-01-2014, 03:30 PM   #33
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Yes, installed without anything touching. But after I went for a drive, I could hear the "tapping" or "rattling" sound. Had to slightly re-adjust the position of the swaybar. (read: yank it downward, away from the beam).
Old 10-04-2014, 02:35 PM   #34
ucsmfu
Drives: yaris le
will this work ?
http://www.ebay.com/itm/261499892257...%3AMEBIDX%3AIT
ucsmfu is offline   Reply With Quote
Old 10-04-2014, 02:42 PM   #35
IllusionX
This. http://m.ebay.com/itm/221295648590?nav=SEARCH
Old 10-04-2014, 03:25 PM   #36
ucsmfu
Drives: yaris le
Originally Posted by IllusionX View Post
same parts number but abit more expensive than the link I posted :P
My Ultra Racing rear sway bar install CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 03-03-2011 03:08 AM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 07:07 AM
TRD rear sway bar cali yaris Items for Sale by private party 19 05-23-2009 06:23 PM
Does the TRD rear sway bar promote tire wear? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-29-2009 11:29 AM
TRD sway bar and tire wear Cutie Pie #2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 02-01-2009 09:07 AM
