Drives: 2007 Toyota Yaris Join Date: Apr 2012
Rear Speed Sensor Install Help? (ABS Sensor)
I have a 2007 sedan, auto 1.5L, and the dreaded ABS and brake light are on. I'm attempting to fix the problem myself. I checked the rear left sensor and the connectors were good. Unfortunately, the right rear sensor connector was corroded and broke off :c
I ordered the parts for the rear speed sensor wire, and I looked at the repair manuals. The repair manuals only show how to replace the front speed sensor wires not the rear. For the rear speed sensor, it only shows to to disconnect it from the abs sensor. Does anyone have any experience in how to replace the rear speed sensor wire or where to find it in the manuals? Thanks! |
Hope u order the harness too u will need it as for sensor it's part of the hub bearing in the rear so u would need to replace hub too .
Sent from my iPhone using Tapatalk |
The rear speed sensor wires go from the sensor up though a floor grommet and into a connecter inside the car. Just follow the wire from the sensor to the floor.
| Tags |
| abs light, abs sensor, brake light, speed sensor |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| Consumer Reports not too pleased with Yaris | Befuddled | General Yaris / Vitz Discussion | 132 | 02-28-2011 03:57 PM |
| Yaris Brake Grinding | Mike R | DIY / Maintenance / Service | 4 | 07-12-2010 11:19 AM |
