Old 04-08-2014, 08:56 AM   #1
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Possible limp mode?
Hey guys,
I just installed a port and polished throttle body on my yaris to go on my blitz supercharger.
I started it up this morning, worked okay until I stopped at a stop sign and it wouldn't go anywhere. I press the gas, nothing happens, and i'm getting a CEL.
The only way I can fix it is to turn off the car and then turn it back on, then the throttle works for a brief moment until I slow down or go around 2k RPM's again.
Not sure what the code is, I was getting a rich condition CEL before but I think this is different.
Any idea why it's doing this? I'm thinking I should switch it back to the old TB.
Black_griffin6 is offline   Reply With Quote
Old 04-08-2014, 09:01 AM   #2
Sounds like the throttle position sensor may be bad on the new TB. You really need to read the code though, as anything else is just speculation.
Old 04-08-2014, 09:03 AM   #3
Black_griffin6
Yeah, I do need to.
Unfortunately it happened on my way to work to catch the bus, and I didn't have time to fool with it much. I'll see what I can come up with. It shouldn't be bad though as it's a brand new throttle body.
Old 04-08-2014, 09:09 AM   #4
Originally Posted by Black_griffin6 View Post
Yeah, I do need to.
Maybe it didn't fare well through the port and polish.
Old 04-08-2014, 09:10 AM   #5
Black_griffin6
That's possible. I'll probably have to swap it out tonight.
Old 04-09-2014, 11:32 AM   #6
Black_griffin6
Swapped it back to stock, works great now.
Must be the position sensor.
Old 04-09-2014, 12:28 PM   #7
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Try a "chip swap".
If your stock chip works, simply put it on the new throttle body. The rivets drill out easily, and small 8-32 nuts and bolts do the job. (throttle body on the right has a bolted on chip)
Greg
limp mode? Golddeenoh DIY / Maintenance / Service 6 06-13-2013 06:08 PM
How to force OPEN LOOP mode on OE ECU?? maxthehax Forced Induction Forum 5 05-27-2013 10:42 PM
does defrost mode affect mileage? nikvolkert Fuel Economy Forum 15 10-21-2010 11:39 PM
