Old 04-14-2014, 02:58 AM   #271
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Originally Posted by trunkout View Post
I just found out.... at 97k.... I had no cabin filter..... so gross.....
Toyota has been famous for this. We actually just buy filters for HVAC units for homes and cut them to fit, tape the cut edges, and install. Saves a lot of cash because you can get 4 filters out of 1. Plus you can get higher levels of filtration.
sent from my m-o-b-i-l-e
Old 08-20-2014, 04:52 PM   #272
nookandcrannycar
8/19/14 (yesterday) - 293,890 miles - 20th oil and filter change for my Bayou Blue 2007 L.
Old 08-20-2014, 07:00 PM   #273
Yaristeve
Drives: 3-door hatch
2011, 3dr hatch, 5-speed, 106k miles.
A/C fan is a little louder and the cup holders buzz a tiny bit if they are open but no drinks in them.
Have done nothing but changed oil (Castrol GTX) every 3k then 4k miles, replaced air filter once, and 1 set of tires which need to be replaced soon.
This is only my second FWD car and I just noticed that these things go through front tires! After "only" 45k miles, the fronts are almost at the wear bars but the rears have a lot of tread left (look new). I guess I should rotate tires every now and then...
The only "mods" are tinted windows, Tanabe Medalion Touring, and Scion wheels.
Old 08-20-2014, 09:00 PM   #274
BobTheYaris
BobTheYaris's Avatar
Drives: '08 Yaris HB 2 dr
'08 3 door hb
red
123,500 mi
regular maintenance and clutch so far
Sent from my iPod touch using Tapatalk
BobTheYaris is offline   Reply With Quote
Old 08-20-2014, 10:11 PM   #275
nookandcrannycar
I thought I was the only one who has experienced this!
I wonder if the roads make a difference. I had a different FWD car when I lived in Orange County (and often drove to different places in LA and LA County) and experienced what you mention above. With my blue Yaris (only a few thousand of all of those miles = on the roads of Southern California) I've averaged 75k per set of 4 (except on two of those sets I squeezed that out of 3 not 4 tires re road hazard replacements)....but I have rotated them .
Old 08-21-2014, 05:14 PM   #276
Hi mpg
Drives: 2010 3dr Yaris
2010 3dr stick shift, just turned 189k.
rear wheel bearing @ 122k
rear brakes @ 162k, I use the hand brake every time I park so they wore out before the fronts. Front pads still look good.
Also had no cabin filter when purchased.
Change oil every 10k with full synthetic, and it's still good according to my UOA
Great little car and cheap to own, I traded in a VW TDI Sportwagen in on it, and glad I did. Only regret is that Toyota won't sell me a diesel Yaris in the USA.
Hi mpg is offline   Reply With Quote
Old 08-22-2014, 02:24 PM   #277
ptitpiffute
Drives: Yaris RS 2007
Hey all,
I've a 2007 Yaris RS absolute red, with about 97k on it.
Appart for the normal maintenance of oil, filters, wipers change, I had to replace my front wiper motor.
Replace the radio, the flashers (plastic teeth broken on both side), the antenna and the battery. I'll have to replace front rotor and pad soon.
Still in very good conditions considering the winters we have here. Since I've had it used, 5 years ago, it has been shot with oil to preserve it from the rust.
ptitpiffute is offline   Reply With Quote
Old 08-22-2014, 05:36 PM   #278
The Limo 2
2007 Sedan purchased new July 27, 2007. (18 Km)
Barcelona Red Metallic.
Follow Toyota Canada Maintenance Schedule.
Wipers changed yearly.
Mar 31, 2015 142,713 Kilometres.
Repairs
1. 17,797 Km Repaired chip in windshield.
2. 18,063 Km Replaced right front tire. Nail in sidewall.
3. 65,885 Km Repaired scrapes on right side of the back bumper.
4. 68,956 Km Replaced driver's side brake lightbulb.
5. 92,104 Km Replaced passenger's side brake lightbulb.
6. 96,840 Km Replaced windshield. Chip and two cracks across windshield.
7. 112,919 Km Replaced serpentine belt.
8. 112,919 Km Performed Recall 177-Lubricated power window switch on driver's door.
9. 125,254 Km Replaced all four tires.
10. 129,537 Km Replaced coolant.
11. 129,537 Km Replaced front brake pads and machined rotors.
12. 129,537 Km Replaced brake fluid.
13. 132,196 Km Four wheel alignment.
14. 134,602 Km Replaced battery.
15. 134,602 Km Performed Recall 233-Replaced driver's side seat rails.
16. 138,583 Km Performed Recall 234-Replaced spiral cable.
17. 139,023 Km Repaired chip in windshield.
Only problem I have had is the key fob has lost its program twice and had to be reprogrammed.
A great little car. We call the car "The Limo" since our other car is a MB smart cdi.
Roy
The Limo 2 is offline   Reply With Quote
Old 08-26-2014, 10:14 PM   #279
albee213
Drives: No longer own a Yaris
2007 Bayou Blue Metallic Liftback Base 25,470 orginal miles.
albee213 is offline   Reply With Quote
Old 08-26-2014, 10:33 PM   #280
nookandcrannycar
You lucky dawg....that was like finding a needle in a haystack . Good for you!
Old 08-26-2014, 11:08 PM   #281
Hershey
That's low mileage . Supermarket runs .
Old 08-26-2014, 11:28 PM   #282
Kal-El
Kal-El's Avatar
Wow. Can't imagine doing only 25K in 7-8 years. TriniPer4mance (member) used to drive that every 2 months!
Old 09-28-2014, 07:37 PM   #283
dfhnpdx
Drives: 2009 yaris
2009 White Yaris
262,000 miles
Repairs: dome light, headlight, water pump, rear axle bearing, front pads and battery
Never left me stranded
dfhnpdx is offline   Reply With Quote
Old 09-29-2014, 08:55 PM   #284
nookandcrannycar
Originally Posted by dfhnpdx View Post
2009 White Yaris
262,000 miles
IIRC, 2009 (your year) = the first year without the OEM alternator having a faulty voltage regulator. I sometimes wonder had my first experience with a Yaris been with the alternator in the 2009, would I still have the OEM alternator in my car (the OEM one with the faulty voltage regulator conked out at just under 160,000 miles).
Old 09-29-2014, 10:57 PM   #285
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
2007 Polar White Sedan
Just on the edge of 66,000 miles
No major repairs yet, just the usual servicing, replacing the rusted horn, having my back bumper repainted (due to it being a rental car and suitcases were being rubbed on it, causing paint to chip) and having to fix a leak in the AC
Starting to put more aftermarket parts into it now so things are looking up
I love the back of my car, the front... not so much
nobodywise is offline   Reply With Quote
Old 09-30-2014, 08:54 AM   #286
chapabig
3dr Angry Bubble
Drives: 07 Yaris HB
07 Bayou Blue 3dr liftback
60,000 miles
No repairs at all
best car ever
chapabig is offline   Reply With Quote
Old 10-23-2014, 12:23 AM   #287
randeez
Drives: 2008 3dr
Originally Posted by randeez View Post
been a little while, had to jump on and order some stuff from Garm(microimage)
brakes are getting a little noisy, passenger side pad, although still having more then 50% material left, looks like it has some stress cracking and pedal feel sucks - ordered new rotors and pads, going to flush all the fluid out as well
for future use:
11/5/11 @ 32,500 (purchased shortly before)
4/12/12 @ 50,000
3/15/14 @ 123,494
Jumped on to see if we needed to be worried bout airbag recall
I see a few more high mileage cars have come around
No issues since last check in, and I get the cup holder buzz, without the cabin filter I also get stuff down in the HVAC blower wheel too
10/23/14 @ 141,000
randeez is offline   Reply With Quote
Old 11-05-2014, 03:29 PM   #288
camoang
Drives: 2007 Toyota Yaris
2007 Yaris Liftback
Blazing Blue Metallic
80,000 miles
2 new sets of tires (both Yokohama ~30,000 & ~60,000)
New brakes last summer (~60,000 miles)
Replaced driver window seal
Nothing other than routine oil changes, etc.
It has started running loud...a friend mentioned maybe the muffler might be bad. Hopefully it's nothing major.
camoang is offline   Reply With Quote
excessive sulfur odor on 2007 model year Yaris tomjasz General Yaris / Vitz Discussion 121 03-13-2010 06:49 PM
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
