![]() Drives: Toyota Yaris auto sedan Join Date: Apr 2014
Starting problems after fuel filter replacement??
Since I've had my fuel filter replaced on my auto yaris sedan (2009) I've had problems starting the car - I would have to crank it for about ten seconds before it would start, it would shudder then start and it was very sluggish. The check engine light was on too. I took it back to the mechanic, they said the O-Ring didn't fit properly, fixed it and sent me on my way. It all worked perfect until I filled up with fuel, and now I have the same problem again. Any ideas what it could be? I can't afford to take it back to the mechanic :(
Thanks |
The mechanic who did the work should be responsible for rectifying the issue. It sounds like he did not properly reassemble the fuel sender assembly and it is leaking off the pressure.
Cheers for that, hoping it's a quick fix! :)
| Tags |
| fuel filter, starting, yaris sedan 2009 |
| Fuel Efficiency and the Yaris | BailOut | Fuel Economy Forum | 327 | 01-02-2026 11:44 PM |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| HELP: Swings but does not start after fuel filter replaced | REV 2 11 | DIY / Maintenance / Service | 12 | 08-19-2013 01:38 PM |
| Fuel Filter | caveatipse | DIY / Maintenance / Service | 27 | 12-28-2012 09:45 PM |
| fuel filter | ias205 | General Yaris / Vitz Discussion | 15 | 05-14-2007 11:02 AM |
