Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
How long do Strut Bearing normal last on the front of the car?
Car has 52k Miles on it, been lowered since original new purchase. Mine are making some really bad noise and they are binding. the bind on turns and can be heard when you approach the steering stops in both direction and when the load shift on the vehicle (initial braking and acceleration).
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
I have run struts for over 100K miles without having the bearings fail. I think them failing prematurely (i.e. before the struts are due for replacing) would be due to them taking hard hits with the suspension bottoming out.
I figured my 55mph on 10mph corners would have some effect, but the roads are rough around here and that does make sense.
You're not the first to have them fail either. I sold a set off the Yaris that I parted out to someone else who had them fail prematurely.
2ZR swap. DO IT! Ask how!
I had one fail last year, but I believe it was related to a defective spring.
Nonsense. You speak silly words. Our cars are meant to do that.
I'm on my 3rd set on my echo. 150K km
| DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 07:52 PM |
| Tanabe front strut tower brace or Ultra Racing strut tower brace? | sternz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 05-14-2010 07:14 PM |
| Rear strut tower bar problem | mrbond | Performance Modifications | 25 | 09-22-2009 03:32 AM |
| Strut bar - To preload or not to preload that is the question | YarisSedan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 04-02-2009 10:38 PM |
| C-ONE Front Strut Tower Bar - Installed & Impressions (Pics to Come) | bigsky2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 01-10-2007 07:53 PM |
