Old 04-29-2014, 07:31 PM   #1
Tintin2
Drives: Yaris and dc2
Engine light
99 toyota yaris 1.0 Change air flow meteor didn't work lambda sensor made car run rougher What is happen is car IDE low engine light on sluggish in morning has to have nearly full tank petrol . When I changed lambda sensor the car would not rev over 2000 when heat up it wouldn't rev over 4000 then cut out when going take off . There's sucking sound in engine bay when ide to low any help
Tintin2 is offline   Reply With Quote
Old 04-29-2014, 07:39 PM   #2
Did you read the code to see why the light was on?
Old 04-29-2014, 08:23 PM   #3
Tintin2
Lean fuel and miss fire
Old 04-29-2014, 08:44 PM   #4
OK. With that and your hiss, it sounds like you have a vacuum leak. Check all of the vacuum hoses and the PCV hose for a leak.
Old 04-30-2014, 05:58 AM   #5
Tintin2
I check all hose no leaks when I squeeze the pipe to black canister it stop the sound the suction pipe when I take of opposite pipe I cannt feel the suction through the canister is that ok . is there any way I check fan in car can I turn on it by
put power to it see if works
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 03:47 PM
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
2012 Yaris LE Check Engine Light On/Eco Light Off 2012YarisLE DIY / Maintenance / Service 1 01-22-2014 12:29 PM
Engine light came on but seems to run fine naossoan DIY / Maintenance / Service 7 06-10-2013 05:51 PM
check engine light, engine turns but not start willygoodness DIY / Maintenance / Service 10 07-23-2012 06:10 PM
