Old 04-19-2014, 01:08 AM   #1
z0mb13k1ll
z0mb13k1ll's Avatar
Drives: '15 Dodge Challenger
DRL relay switch
Looking to add a switch to the power line on the DRL relay for my car. Is this possible or would it mess something up? I go to the drive-in often and have to unplug the relay under the dash. Socicwould like to have a switch on the dash that cuts the power to it effectively turning off the DRL lights. Lemme know if it's as easy as I hope! Thanks
z0mb13k1ll is offline   Reply With Quote
Old 04-19-2014, 07:47 AM   #2
Just add a switch inline with the large blue wire in pin 1 of the DRL.
Old 05-04-2014, 04:03 PM   #3
z0mb13k1ll
z0mb13k1ll's Avatar
Awesome, thanks. I will let you know how it turns out when I get around to it.
Old 05-04-2014, 05:35 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
with the hand brake up they stay off...so when ur at the movies turn car off , brake up restart ....or do what Scott said lol
I was wondering how hard would it be to run my DRL to the little park bulbs in the main head light ?
Old 05-04-2014, 07:29 PM   #5
I believe that you could clip the large blue wire in pin 1 of the DRL connector and feed what every you want with it.
Old 05-04-2014, 08:38 PM   #6
IllusionX
Drives: 07 Yaris Sedan Aero
i fed mine to the orange wire for the fog lights, but i did need to add a capacitor in order to get around the pulsed +12v that blue wire gives.
Old 05-04-2014, 09:54 PM   #7
You needed the cap as you are driving the relay, rather than the lights. Bulbs do fine with the pulsed power, but when you feed it through a relay you get flickering.
Old 05-05-2014, 12:29 AM   #8
trunkout
4 years of P90X!
Drives: 09 Yaris Sedan
just ran mine to the fuse box under the hood. found a spot that is ACC. Lights are on as long as ACC is on (running basically) with no relay. Cant believe LEDs draw that much power.
trunkout is offline   Reply With Quote
diy, drl, wiring
DIY - Exterior lights on when doors are remotely unlocked CTScott DIY / Maintenance / Service 21 07-31-2025 07:30 PM
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 09:42 PM
Need fog light switch and relay Jrilla DIY / Maintenance / Service 23 07-01-2011 12:12 PM
Can anyone confirm if we can relay hid on yaris with drl? marcus Cosmetic Modifications (Exterior/Interior) 0 06-10-2010 01:38 PM
DRL Relay andru47 Willing to Buy by private party 1 01-06-2009 06:47 PM
