Old 05-09-2014, 10:12 AM   #19
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by BobTheYaris View Post
Change mine every 30,000 on every car I've owned. Don't care what manufacture says
Sent from my iPod touch using Tapatalk
at 17.50$ the plug, are you sure?
Old 05-09-2014, 10:47 AM   #20
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Ouch! Where do you purchase at?
NGK IFR5A11
In my experience NGK plugs are just as good or better than DENSO
I can go to my local CarQuest and get them for even less than the $8+ on Amazon. The net price on them is around $4 each so even at the $8+ is one hell of a markup!
Old 05-09-2014, 11:27 AM   #21
IllusionX
dealer sells them at 17.50$ each.
obviously i didn't go with those. I think i paid 35$ or so for a complete set of denso on ebay.
Old 05-09-2014, 12:01 PM   #22
fnkngrv
fnkngrv's Avatar
Gotcha.
Yeah, I would have to be in a real bind to buy at the stealership with how damned unreasonably expensive they usually are.
sent from my m-o-b-i-l-e
Old 05-09-2014, 12:14 PM   #23
IllusionX
I guess it depends on what you buy.
I always get my oil filter from the dealer (at least when i have time to pass by). they are only 6.99$ + taxes
Old 05-09-2014, 12:19 PM   #24
fnkngrv
fnkngrv's Avatar
I suppose that maybe I am an exception since my "local" dealership is 60 miles one way away.
Old 05-09-2014, 12:39 PM   #25
IllusionX
everything is far in the US. lol
There are at least 6 toyota dealers around the area within a 20mi radius here. LOL
Old 05-09-2014, 11:54 PM   #26
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
Hi everyone.
I was changing oil today and decided to check sparkplugs to see how they are wearing at 70,000 miles. The plugs came too easy for so many miles. It turned out the dimwit previous owner replaced 120,000 mile OEM iridium with some aftermarket junk. Bosch Platinum +4. What is this junk?
The plugs looked just like these:
jack black is offline   Reply With Quote
Old 05-10-2014, 12:16 AM   #27
fnkngrv
fnkngrv's Avatar
Bosch generally doesn't make junk. As for using non-iridium I haven't used iridium plugs for most of the life of my car without issue.
Old 05-10-2014, 01:00 AM   #28
jack black
jack black's Avatar
Bosch plugs have a well deserved reputation for this:
or that:
Old 05-10-2014, 03:25 AM   #29
kubota99
Drives: 2007 Yaris hatchback
Originally Posted by jack black View Post
Hi everyone.
Funny you call these junk! They're the top of the line platinums.
As for the pictures you just posted, my NGK's I had in 3 weeks ago did the same thing than those Bosch plugs.
kubota99 is offline   Reply With Quote
Old 05-22-2014, 06:20 PM   #30
jack black
jack black's Avatar
Well, I called them junk, because I was pretty sure they were not as good as the OEM NGK long life 0.7mm Iridium center/platinum puck ground strap plugs. I'm familiar with that OEM plug as I had the same thing in my RIP corolla with 1ZZ-FE engine.
I knew about frequent problems with defective Bosch plugs, but, not being familiar with this weird 4-ground electrode, I looked it up. Apparently they are notorious for misfires and poor engine performance.
Part of the problem is explained in this study: http://wenku.baidu.com/view/d5c9374c...fa1c7cde7.html
+4 were the worst plug in that study (table 9) due to the massive +4 ground electrode quenching the flame kernel. Notice that the +2 did actually well. More is not better.
Another problem is the cheap tiny 0.4 mm pure platinum electrode. Long life plugs require either 0.7 mm iridium or 1.1 mm platinum electrode (and platinum on ground electrode). 0.4 mm pure platinum has very short life, no more than 20,000-30,000 miles.
Clueless +4 buyers (like the previous owner of my car) are sucked into buying this overpriced, low performance, and low life plug, keep it forever (platinum, baby) and have nothing but problems. I'm swapping them for denso platinum TT plugs this weekend.
Old 05-22-2014, 07:37 PM   #31
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
They're installed with proper antiseize compound at the factory, and gapping's not recommended with the iridium plugs. It is highly advisable to let the engine cool completely before removing plugs from an aluminum head, and to use a torque wrench when installing the new ones, though these are plugs that use a gasket and thus have some leeway on installation torque. If you ever strip the plug hole threads in the head, though, you'll wish you hadn't.
i guess u have never worked flat rate...lol that is good idea if u do it urself but honestly not many shops will ...hot or cold they come out lol
Torque is ...snug plus one lol
Old 05-22-2014, 07:40 PM   #32
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
That is a waist of $$$ and not necessary , old school thinking
Old 03-20-2016, 01:50 PM   #33
Pingolfer
Pingolfer
Drives: 2007 Toyota Yaris 3 door hatch
never regap a platinum or iridium plug ( you will render it useless ). Also NGK plugs do NOT need anti-seize, as a matter of fact, NGK say NOT to use it, the chrome threads have an anti-seize built into them. Use anti-seize on Autolite or bare steel threads plugs only
Pingolfer is offline   Reply With Quote
Old 03-21-2016, 04:34 PM   #34
Pingolfer
Pingolfer
never regap a platinum or iridium plug - it will render them useless. No need to use ant-sieze on NGK plugs, they do not require it, and it is recommended by NGK tht you do not (using it is detrementral). Use never-
sieze only on plain steel threads like Autolite plugs, AC Delco
Old 03-22-2016, 02:32 PM   #35
jack black
jack black's Avatar
you resurrected the old thread just to say this?
the real reason not to use anti-seize is because it messes up the torque value. It's OK to use anti-seize AND decrease torque.
Old 05-17-2017, 07:55 AM   #36
Goosecreekjoey
Drives: 2008 yaris
What does Toyota know anyway, RIGHT. 100,000. THEY KNOW WHAT THERE TALKING ABOUT.
Goosecreekjoey is offline   Reply With Quote
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 03:07 PM
Where do I buy ngk iridium tip 7 heat spark plugs? PETERPOOP Performance Modifications 23 03-08-2009 09:34 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 02:53 PM
Dual ground electrode spark plugs Kitt DIY / Maintenance / Service 15 02-09-2009 12:08 PM
Spark Plugs YamilR DIY / Maintenance / Service 2 09-28-2007 09:38 PM
