Old 05-20-2014, 12:55 AM   #1
barefoot_bajan
barefoot_bajan's Avatar
Drives: 02 vitz rs
1nz throw out bearing D.I.Y?
anyone ever change the throw out bearing for the 1nzfe?
looking for a repair manual, but not seeing one.
so many pedestrians..... so little time
barefoot_bajan is offline   Reply With Quote
Old 05-20-2014, 09:01 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Check out microimageonline.com. They have the whole OEM manual available in pdf. The bearing itself takes only a few seconds to replace. Getting the transmission off takes several hours.
Old 05-24-2014, 09:41 AM   #3
barefoot_bajan
Drives: 02 vitz rs
ok... def not seeing it, can someone please post it here from microimage.
Old 05-24-2014, 11:25 AM   #4
CrankyOldMan
http://microimageonline.com/forums/s...TECH-TSB-FILES
Old 05-24-2014, 01:12 PM   #5
barefoot_bajan
Drives: 02 vitz rs
THANKS
Alternator Bearing barryware DIY / Maintenance / Service 7 11-23-2013 07:33 PM
Bad trans bearing Topaz540i DIY / Maintenance / Service 9 04-15-2013 03:51 PM
Yaris 2007 ABS & Brake light issue after wheel bearing change DevilzMafia DIY / Maintenance / Service 4 01-17-2013 10:24 PM
Throwout Bearing Failure blazing hatch DIY / Maintenance / Service 7 06-03-2012 09:44 PM
Urgent advise Needed MT Clutch & Bearing Spec. victorddr DIY / Maintenance / Service 4 04-23-2011 11:27 AM
