Old 06-29-2014, 04:23 PM   #1
Henry_mak16
Henry Mak
Drives: 2009 Toyota Yaris 2dr-hatchbk
Coilovers vs TRD Suspension?
What is the main difference between coilovers vs trd lowering springs + trd shocks (http://www.toyotaracing.com/trd/part...tegories=all)?
Expecting more of a scientific answer as to how it works. Thanks!!
Henry_mak16 is offline   Reply With Quote
Old 06-29-2014, 06:38 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Coilovers are made with full adjustability. Either height, bound and rebound or all of the above.
TRD springs + shocks are well just that...
Old 06-29-2014, 06:42 PM   #3
Rigaud
Drives: 2009 Yaris
More then just that if you purchase proper springs and struts also for those that know what their doing. Same for coil overs you need to know what your doing or get help.
Old 06-29-2014, 08:35 PM   #4
Adjustable ride height and spring rate vs. Static ride height and spring rate.
That's pretty much what it boils down to. No need to get scientific about it.
Old 06-30-2014, 04:01 AM   #5
mr_miles
Drives: 2013 Yaris
+1, coil overs give you adjust-ability of everything. ride height, shock stiffness, spring length / stiffness, it all boils down to what you want and how you want it. If your likings change, so can the coil overs. Lowering springs can be a let down if you don't already know exactly how you want it :x
Old 06-30-2014, 08:00 AM   #6
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
You can also continue to swap in shorter and stiffer springs if you want to keep going lower, once you pickup some tein springs thats as short as you will go on springs/shocks combo and it is less than 2" of drop. Stiffer allows you to control spring rate and you can go into 1000 lb springs or higher if you so desire, springs probably dont go higher than 5-6k
Old 07-06-2014, 05:06 PM   #7
j-san
Drives: 2010 5-door hatchback
Are there coil-over sets that match the stock ride height? Every coil-over kit I see for the Yaris is made for lowering.
j-san is offline   Reply With Quote
Old 07-06-2014, 05:51 PM   #8
Why would you want to spend coilover $$s, if you are looking to match stock height? You looking to get higher spring rate, while maintaining OE height?
The primary purpose of coilover is so a person can set height to whatever tickles their fancy. I do believe that with the spring perch at full up, a coilover matches, or comes close to, stock height.
Old 07-06-2014, 11:49 PM   #9
j-san
Yup, stiffer spring rate at stock height. I'm not a fan of lowering my car, but I would like to try and improve the handling at the stock height. My car is probably due for new shocks and struts so I am just curious about the differences.
Old 07-07-2014, 12:27 AM   #10
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
i say go with TRD sprigs and new struts , TRD is made by KYB i think as best solution for you ...very little drop with TRD springs but much better than stock also get the rear TRD sway bar that makes a huge diff on Yaris....maybe some wider tires/rims etc.
ps ...TRD drop is .5 up front and 1.5 rear ..it levels the car nice
Old 07-07-2014, 07:55 AM   #11
1.5
Form>Function
1.5's Avatar
you can adjust your coilovers to be pretty high but idk about all the way up to stock height
Old 07-10-2014, 08:47 AM   #12
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Most coil's won't go to stock height, but some will only lower it an inch or two. The Yaris sits so high an inch or two is not that big a deal unless you need to go off road a lot.
The real difference is in the ride. Some shocks like the Tokico Reds are adjustable, and can ride really softly, and so can some coilovers. Others are rather harsh.
Colin Chapman disciple
Help with sizes for wheels running TRD suspension. Captain Slow Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 12-07-2011 07:48 PM
Sedan owners with full suspension mods? specifically all TRD AdeJong 03 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 05-15-2010 01:13 PM
trd suspension elijahsami Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 11-09-2009 06:15 AM
For Sale: TRD sportivo suspension Hocc Australia 8 10-16-2009 08:24 AM
09 LB - Scion rims + TRD Suspension regal Photo-Video-Media Gallery 8 04-18-2009 12:05 AM
