Old 07-13-2014, 01:16 PM   #1
salmanghiyas
Fugitive
Drives: 2007 Yaris 4 Door Hatch
Fluid for engine
Hello guys Plz recommend engine oil and oil grade for vitz RS 1.5L ( engine - 1nz fe ) manual tranny 30000km driven .
salmanghiyas is offline   Reply With Quote
Old 07-13-2014, 02:46 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Depends in your area. Otherwise, the grade is written on the oil cover. Usually it is 5w30.
Old 07-13-2014, 03:40 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
You can run 0w20 ,5w20 or 5w30 in a Yaris I use 5w30 synthetic :)
Old 07-13-2014, 08:05 PM   #4
salmanghiyas
Fugitive
thx all for the suggestive replies ...
well .. adding a bit more info ... temperature where i am usually remains HOT .. around 30 to 38 degree Celsius on an average .. its a coastal area so humidity always remains high ... we do not have clear and carpet roads here and the traffic is messy as well ... so the car mostly runs on low gears ... average speed on road is around 20 to 30 KM/h
ive heared from a person that if the temperature is HOT and car runs on low gears then dont go for synthetic .. either go for semi synthetic or the conventional oil ... and also do use higher oil grade .. like 10w 40 or 20w 40
Old 07-13-2014, 08:56 PM   #5
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
OK ..well then either use 5w30 or go up to 5w40 for ur area I like using 5w40 in out Juke in summer months cos of the turbo and back to 5w30 winter both synthetic.
Old 07-13-2014, 09:52 PM   #6
salmanghiyas
Fugitive
Awrite mate ...
Fully synthetic 5w 40 ?
mine is bone stock RS ... and what oil brand should i opt ? or just simply go to the toyota shop and buy the toyota motor oil
Old 07-13-2014, 10:14 PM   #7
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Ya full synthetic 5w30 or in ur case 5w40 ...Toyota has either regular or for extra syn oil but won't have 5w40 ...u see 5 means start up are both same but by going to 40 the oil will stay thicker at high temp so won't fin out think it would be ideal for ur application ..hot weather and stop and go traffic .
Old 07-13-2014, 10:32 PM   #8
salmanghiyas
Fugitive
Gr8
Thxx a lot !!!
Old 07-14-2014, 02:28 PM   #9
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
You wont have a problem with any synthetic 10w-30 product, your owners manual will probably explain in more specific detail.
Have Yaris will travel..
Old 07-15-2014, 09:14 AM   #10
salmanghiyas
Fugitive
Ive bought a 2nd hand car ... So there aint any manual in it :S
Old 07-15-2014, 09:19 AM   #11
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
5w30 is stock for Yaris 1.5
Old 07-15-2014, 10:53 AM   #12
IllusionX
oil grade should be written on the oil cap on the engine. Unless it has been changed for an aftermarket one..
Old 07-15-2014, 12:00 PM   #13
trunkout
4 years of P90X!
Drives: 09 Yaris Sedan
full synthetic. 5w30. MOST small 4 cylinders will be just fine with this.
trunkout is offline   Reply With Quote
Old 07-16-2014, 08:35 AM   #14
salmanghiyas
Fugitive
Im not getting 5w30 neither 5w40 .... Only oil grade in full synthetic im getting here is 5w50 ... What should i do ?
Old 07-16-2014, 08:44 AM   #15
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
50 maybe little much stick with regular but 5w30 ,40 then
Old 07-16-2014, 09:07 AM   #16
What should i do ?
Have you bothered to get a recommendation from Toyota Service Dept? Would be interesting to see what they say and compare it to advice that you're getting from people who don't live anywhere close to Pakistan.
Old 07-16-2014, 09:09 AM   #17
salmanghiyas
Fugitive
Well to be very honest ... We cannot even rely or take suggestions from toyota dealers here ... The oil which im getting is Mobil-1 5w50 which is im sure id genuine ...
Old 07-16-2014, 05:37 PM   #18
nookandcrannycar
Nice .
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Brake/Transmission Fluid questions Rutherford DIY / Maintenance / Service 1 02-06-2014 05:22 PM
So when DOES the transmission fluid need to be changed dutchy999 DIY / Maintenance / Service 12 09-06-2011 05:18 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
