Old 05-01-2007, 07:37 PM   #1
redyaris
Shiny Chromey Coolness
redyaris's Avatar
Drivers Side Seat Belt Won't Retract
My driver side seat belt doesnt like to retract. I took to the dealer and they 'documented' it. Guess ill have to play their game and take back again with the proper bitchy attitude 'fix it or die'....
Anyone else had this issue? The front passenger belt works like a charm.
Old 05-01-2007, 07:54 PM   #2
spkrman
Drives: 1
never had a car that had perfect seat belts, always takes some playin with.
If it just "won't" go back, def go to the dealer and biotch.
Old 05-01-2007, 08:05 PM   #3
uncleyaris
tank God, you still got the warrenty
Old 05-01-2007, 08:50 PM   #4
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
What dealer would want to play games with a key piece of safety equipment? If that belt doesn't work correctly in a crash, they're screwed.
I'd write a very clear (polite and not overtly threatening) letter to their service manger and copy Toyota Corporate.
Old 05-02-2007, 07:46 PM   #5
punch
punch's Avatar
Drives: 2007 Yaris Sedan "D" package
did you try to reset it, pull it out all the way then slowly let it back in...
punch is offline   Reply With Quote
Old 05-03-2007, 12:14 AM   #6
redyaris
redyaris's Avatar
Yeah the service guy did that a few times. Immediately after i drove off the lot and parked, it didnt retract.
Funny, while I was waiting at the service line the teenage porter said 'cool car' and 'do you know Ran?' and said he had heard of this in a few Yaris already.
Old 08-07-2014, 09:39 AM   #7
driverofchuckles
driverofchuckles's Avatar
Drives: 2008 Yaris. Manual everything
I'm having the same issue with my 08 3 door hatch. I'm about to take the panels off to lube it and see if the unit is just dirty. I'll report back if I fix the problem.
driverofchuckles is offline   Reply With Quote
Old 08-07-2014, 10:28 AM   #8
lubing it won't help. The recoil spring gets tired over time, so about the only thing you can do with it is to take the whole recoil assembly apart and pretension it a couple more turns.
Old 08-07-2014, 10:37 AM   #9
driverofchuckles
I was able to access the rewind unit but came to that exact conclusion. I'm going to save that project for when I upgrade the rear speakers since I will have to remove those panels anyway. For now it's onto removing the fabric from the front doors and clean the adhesive off.
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 09:15 PM
Drivers seat - wire sticking through cover on back. azeeroth DIY / Maintenance / Service 1 03-30-2013 10:37 AM
Seat Belt Problem wagon DIY / Maintenance / Service 1 03-06-2013 10:37 AM
Seat belt reminder warning Beep Jord DIY / Maintenance / Service 28 04-09-2009 08:37 AM
