#271 | |
Mr. 155 and climbing
sent from my m-o-b-i-l-e
#272 |
8/19/14 (yesterday) - 293,890 miles - 20th oil and filter change for my Bayou Blue 2007 L.
#273 |
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
2011, 3dr hatch, 5-speed, 106k miles.
A/C fan is a little louder and the cup holders buzz a tiny bit if they are open but no drinks in them. Have done nothing but changed oil (Castrol GTX) every 3k then 4k miles, replaced air filter once, and 1 set of tires which need to be replaced soon. This is only my second FWD car and I just noticed that these things go through front tires! After "only" 45k miles, the fronts are almost at the wear bars but the rears have a lot of tread left (look new). I guess I should rotate tires every now and then... The only "mods" are tinted windows, Tanabe Medalion Touring, and Scion wheels. Last edited by Yaristeve; 08-20-2014 at 07:12 PM. |
#274 |
'08 3 door hb
red 123,500 mi regular maintenance and clutch so far Sent from my iPod touch using Tapatalk |
#275 | ||
#276 |
![]() Drives: 2010 3dr Yaris Join Date: Oct 2010
2010 3dr stick shift, just turned 189k.
rear wheel bearing @ 122k rear brakes @ 162k, I use the hand brake every time I park so they wore out before the fronts. Front pads still look good. Also had no cabin filter when purchased. Change oil every 10k with full synthetic, and it's still good according to my UOA Great little car and cheap to own, I traded in a VW TDI Sportwagen in on it, and glad I did. Only regret is that Toyota won't sell me a diesel Yaris in the USA.
#277 |
![]() Drives: Yaris RS 2007 Join Date: Jul 2009
Hey all,
I've a 2007 Yaris RS absolute red, with about 97k on it. Appart for the normal maintenance of oil, filters, wipers change, I had to replace my front wiper motor. Replace the radio, the flashers (plastic teeth broken on both side), the antenna and the battery. I'll have to replace front rotor and pad soon. Still in very good conditions considering the winters we have here. Since I've had it used, 5 years ago, it has been shot with oil to preserve it from the rust. Last edited by ptitpiffute; 08-22-2014 at 07:43 PM. |
#278 |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Oct 2012
2007 Sedan purchased new July 27, 2007. (18 Km)
Barcelona Red Metallic. Follow Toyota Canada Maintenance Schedule. Wipers changed yearly. Mar 31, 2015 142,713 Kilometres. Repairs 1. 17,797 Km Repaired chip in windshield. 2. 18,063 Km Replaced right front tire. Nail in sidewall. 3. 65,885 Km Repaired scrapes on right side of the back bumper. 4. 68,956 Km Replaced driver's side brake lightbulb. 5. 92,104 Km Replaced passenger's side brake lightbulb. 6. 96,840 Km Replaced windshield. Chip and two cracks across windshield. 7. 112,919 Km Replaced serpentine belt. 8. 112,919 Km Performed Recall 177-Lubricated power window switch on driver's door. 9. 125,254 Km Replaced all four tires. 10. 129,537 Km Replaced coolant. 11. 129,537 Km Replaced front brake pads and machined rotors. 12. 129,537 Km Replaced brake fluid. 13. 132,196 Km Four wheel alignment. 14. 134,602 Km Replaced battery. 15. 134,602 Km Performed Recall 233-Replaced driver's side seat rails. 16. 138,583 Km Performed Recall 234-Replaced spiral cable. 17. 139,023 Km Repaired chip in windshield. Only problem I have had is the key fob has lost its program twice and had to be reprogrammed. A great little car. We call the car "The Limo" since our other car is a MB smart cdi. Roy Last edited by The Limo 2; 03-31-2015 at 06:12 PM. |
#279 |
![]() Drives: No longer own a Yaris Join Date: Jul 2014
2007 Bayou Blue Metallic Liftback Base 25,470 orginal miles.
#280 |
#281 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
That's low mileage . Supermarket runs .
#282 |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
#283 |
![]() Drives: 2009 yaris Join Date: Jul 2012
2009 White Yaris
262,000 miles Repairs: dome light, headlight, water pump, rear axle bearing, front pads and battery Never left me stranded |
#284 |
IIRC, 2009 (your year) = the first year without the OEM alternator having a faulty voltage regulator. I sometimes wonder had my first experience with a Yaris been with the alternator in the 2009, would I still have the OEM alternator in my car (the OEM one with the faulty voltage regulator conked out at just under 160,000 miles).
#285 |
2007 Polar White Sedan
Just on the edge of 66,000 miles No major repairs yet, just the usual servicing, replacing the rusted horn, having my back bumper repainted (due to it being a rental car and suitcases were being rubbed on it, causing paint to chip) and having to fix a leak in the AC Starting to put more aftermarket parts into it now so things are looking up I love the back of my car, the front... not so much |
#286 |
3dr Angry Bubble
Drives: 07 Yaris HB Join Date: Jun 2014
07 Bayou Blue 3dr liftback
60,000 miles No repairs at all best car ever |
#287 | |
![]() ![]() Drives: 2008 3dr Join Date: Oct 2011
![]() I see a few more high mileage cars have come around No issues since last check in, and I get the cup holder buzz, without the cabin filter I also get stuff down in the HVAC blower wheel too ![]() 10/23/14 @ 141,000 |
#288 |
![]() Drives: 2007 Toyota Yaris Join Date: Sep 2014
2007 Yaris Liftback
Blazing Blue Metallic 80,000 miles 2 new sets of tires (both Yokohama ~30,000 & ~60,000) New brakes last summer (~60,000 miles) Replaced driver window seal Nothing other than routine oil changes, etc. It has started running loud...a friend mentioned maybe the muffler might be bad. Hopefully it's nothing major. |
| excessive sulfur odor on 2007 model year Yaris | tomjasz | General Yaris / Vitz Discussion | 121 | 03-13-2010 06:49 PM |
| TSB's | WD-40 | General Yaris / Vitz Discussion | 27 | 06-06-2007 01:11 AM |
