![]() ![]() Drives: White Yaris Sedan Join Date: Mar 2014
Should I get an alignment?
Hello, I've recently had my alignment checked at Just Tires for my '07 Yaris and everything checked out great except for the right front passenger side which measured at -0.9 cross camber which is the maximum it can go for the Yaris. I'm about to get new tires soon (General RT43) and want to make sure they are taken care of so would the alignment be necessary eventhough it's right at the maximum at -0.9.
I'm thinking I should get the alignment, however Just Tires also said I needed a camber kit which would cost $180 so I said no way. I'll do it without the camber kit and even than there is no guarantee they can get it within a positive range. What do you all think? Thanks in advance.
What are the actual camber degree for both front wheels?
When I did my car after I put teins in it my camber is at 0.0 both sides ...but yes is only one side out or are they both about same or similar amount .
The side u mention is the curb side ..common problem with city driving and curbs getting hit lol sent from my S4 on Mars |
#4 | |
The range for a '07 Yaris fronts are -0.9 to 0.6. As you can see I'm right at the edge -0.9 on the front passenger side.
No camber kit at all if I'm not mistaken the yaris stock caber is 0 up front and lowering had no effect on it just toe , that I had to reset was out by about 5 degree each side .
You could try and loosen the lower 2 strut bolts and see if that helps they dont have adjustments but sometimes it helps that bit ...so loosen and re tighten bolts ...this works best on alignment rack . sent from my S4 on Mars PS to answer ur original question , new tires = alignment check and do if needed |
Only Happy When it Rains
What is the camber of your other front tire. That is more important and will tell us if you really need an alignment or not.
Colin Chapman disciple |
Cross camber is just telling us that there is a difference between left and right camber, meaning biased to one side. But we want to know the actual measurements for left and right to help you.
#8 | ||
![]() Also if I did need an alignment, should I do it at the local shop or Toyota Dealership? Seeing that they have a special at the dealership for an alignment which is about the same price as the local shop. Thanks in advance.
Ok i see what you are trying to say.
Driver side is set to 0 degree Camber, and Passenger is -0.9 Camber = Passenger bias cross camber of -0.9. People run with more camber than that and its ok, mainly for looks and fitting low offset tires, among other things. Im sure the car pulls mighty to the left. Camber bolts dont cost that much at all, its just 1 bolt and not like a camber plates or stuff. For instance: http://shop.microimageonline.com/Adj...olts-81270.htm But try loosening the two shock bolts and give a nice tug on the top of wheel to even it out. If the car tracks straight you know you got it at least pretty close.
| Vehicle pulls after alignment | salmonz | DIY / Maintenance / Service | 6 | 12-11-2010 05:17 PM |
| Alignment Question | gsf1200m | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 10-16-2009 10:35 AM |
| WOW What a difference an alignment makes!! | YarisSedan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 10-12-2009 05:29 PM |
| understeer | DOMAV | General Yaris / Vitz Discussion | 31 | 09-30-2009 07:01 AM |
