![]() Drives: Toyota Yaris sedan 2009 Join Date: Jun 2012
A/T Jerks @ 4th Gear
Please help, I have 2009 Yaris Sedan, I have noticed that my car jerks when the gear shifts specially in 4th gear. I just had transmission fluid/filter change but jerking is still there. Thanks
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
I have the hatch and mine does the same thing under heavy acceleration about 30 miles ago. Had a transmission shop do it but they didn't do a complete flush as they gave me extra fluid back. I posted a thread about it but to tired to find it. Never resolved it just now I let off the pedal before 4th when going up hill and mashing it. Putting it in 3rd helps on hills.
![]() Drives: 2007 Yaris Sedan Join Date: Nov 2014
Had exactly same issue. Flushed all fluid i changed filter. Filled back in as on instruction 2.6qt took her for test ride notice jerking between 3rd and 4th gear. Came home and check level. Was very low. So I added another qt checked again was still low. Added what I had left 0.4 so total was 4qt. Took for test ride jerking was gone. However level was still low. Then I measured drained fluid was over 1gl!!!! I had 1gl empty can from milk so it overflows. Get Toyota dealership this morning and bought another 2qt. So I ended up putting 5.4qt. Technician from Toyota said actually in some cases torque converter might be in position when all "holes" lined up and it actually flushes!!
Wow another excellent reason NOT to change the auto transmission oil!
| 2nd, 4th & Reverse Gear Not Engaging | mesci | DIY / Maintenance / Service | 3 | 03-17-2023 08:03 AM |
| Experimenting with bypassing the AT 4th gear prohibition when cold | CTScott | Performance Modifications | 28 | 03-22-2015 09:16 AM |
| hesitation into 4th gear AT | samus11 | DIY / Maintenance / Service | 5 | 12-18-2012 09:22 PM |
| Grinding in 4th gear? | Black_griffin6 | DIY / Maintenance / Service | 8 | 05-30-2012 04:54 PM |
| No 4th gear in A/T? | caineroad | General Yaris / Vitz Discussion | 13 | 09-11-2009 07:47 PM |
