![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
This right there is why ppl hate stealerships
Went to get my recall work (spiral cable, seat rails) done, and they gave my car a "multi point inspection."
This is what they said they've found wrong with it: ![]() And this is how much they said they'd charge to fix it: ![]() Oh no, that all sounds important, but I'm sure they had a good look and I can trust them, right? Well lets have a look at the bits I can easily check and verify: Filled washer fluid to proper level: Bone-dry. ![]() Adjusted tire pressure to 36 psi: ![]() Serpentine belt cracked/damaged: ![]() I'm half tempted to get a brake fluid spindle and check that too. As far as the "running rough" goes? Bullcrap. I had cars that run rough. I've had cars that were quieter inside, but those weren't Yarisses. I'll accept that maybe the brake fluid, and MT fluid could be changed, and based on mileage, a new serpentine belt might not be a bad idea one of these days, but going by what they said is wrong with my car and the work they said they did, for all I know the recall work wasn't done either and all they did was run it through the car wash and sprayed some tire shine on the wheels. When I get it done, I sure as hell won't have Toyota of Grapevine do it. |
Replace belt for $166 lmao I think that place is on crack ! That is just crazy !
I work at Toyota and sure we can be little more but nothing like ur estimate bill lol sent from my S4 on Mars |
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
You spelt Stealership wrong
Did I now?
It did not say the tire pressure was adjusted. It was a suggestion.
Anyways.. Your belt does show cracks. Look at the inside of the belt. And 100+$ for the belt and labour is about right to me. |
#6 | |
Minimalist
Drives: 07 silver sedan Join Date: Jun 2014
#9 | ||
Just did the spark plugs myself, and WITH buying a ratchet and extension, and a 16 mm socket, I was still under $50 and it took less than five minutes. |
That's the sad reality of garage work now. Nothing is charged by actual time required. It's all 'job' cost.
#11 | |
If one needs a shop go to hourly place cos at least ur know its gone be done with out rush . sent from my S4 on Mars |
World Class Inspection, lol!
Maybe get it checked at a different Toyota dealership. I'm sure there's lots in the Dallas/ Fort Worth area. Also, you can clean your throttle body easily, just purchase some throttle body cleaner spray. It would save you the 89$ + tax + labor. |
Only Happy When it Rains
Doing a check like that is not surprising, it is a chance for the dealerships to try and make money, after all the are businesses.
However I agree those prices are nuts. A good independent mechanic would do it for half that.
Colin Chapman disciple |
#14 |
#15 |
![]() ![]() Drives: White Yaris Sedan Join Date: Mar 2014
Besides the usual rudeness like being hung up on and such the dealership I go to hasn't tried to upsell yet at least. I never let my guard down when at dealerhships in fact it's heighted. I will assume they're lying everytime they open their mouths.
#16 |
Yeah but that crowd probably doesn't drive seven year old Yarisses, and did I mention that's still the newest car I've ever owned, even now that I've driven it for two years.
#17 |
I don't know how i would live in the states. Dealers are so far from each other they easily take advantages of people.
#18 |
except most people in the US only go to dealerships if they have to. Most of the time their is a great mechanic around that will charge much less and do a better job.
| I hate birds!!!! | Buckethead | DIY / Maintenance / Service | 19 | 03-17-2012 10:06 PM |
| Anyone Else Hate The Yaris Steering Wheel? | PhilD424 | Cosmetic Modifications (Exterior/Interior) | 55 | 01-24-2011 07:08 AM |
| Have I mentioned how much I hate Speed sensors? | staticorex | General Yaris / Vitz Discussion | 13 | 05-28-2009 04:04 PM |
| How many ppl are rocking stock shocks? | Riced-yaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 31 | 05-05-2009 02:08 PM |
| Hate for Yaris? | redyaris | General Yaris / Vitz Discussion | 35 | 03-01-2007 07:58 PM |
