#19 |
![]() ![]() ![]() Join Date: Sep 2014
my english is too short....pictures "talk" more
tail light in curt wire work stop light in curt wire work |
#20 |
tail and stop light pict.
#21 |
OK. From the pictures of the right side connector I can't tell which blue lines up with which wire on the top of the connector, but the darker blue (called sky blue) wire is the right turn signal wire.
#22 |
ok, i do you mean, that i will change the tap to the dark blue wire
#23 |
Actually I was remembering the blue colors wrong. The lighter blue is "sky blue". So, you want to connect to that wire or to the wire that it connects to on the other side of the connector.
#24 |
CTScott, please see this pict...
#25 |
OK. So you are on the correct wire. Make sure your tap splice is actually making contact through the insulation.
#26 | |
tap splice is making contact, i did a "test"connect direct the green wire from wire connector, to a and do not work |
#27 |
Try switching the left and right input wires on the curt and see if the problem stays on the right. If it does then the curt unit is the problem.
#28 |
Thank you, i will do tomorrow, if not Work... I will need some help to Write to seller...
#29 |
Ctscott i did that you said.. Change the left to right and the curt unit is the problem..
I bought from Amazon And they ship to friend house. I need help to ask a New one... With the correct words |
#30 | |
"I recently purchased a Curt trailer light converter from you. After installing the unit I found that the right side turn signal does not work. I switched the right and left turn signal wires to the Curt converter and the problem remained on the right side, so the unit is definitely bad."
#31 |
Thank you... Do you think they want the damage unit... Becouse my friend will go in two weeks to USA
#32 |
Yes. They will probably want the bad one back.
#33 |
is good or bad idea if "we" add this words
"I send this to my cousing in México And he back to USA in two weeks," |
#34 |
I would leave that off.
#35 |
May i buy a universal wire connector or i need the specific wire connector
. If its universal i will try to find here in México |
#36 |
Any universal one will work.
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 09:47 AM |
| Help me install my Infinity Basslink! | wsladaritz | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 10-21-2008 01:15 PM |
| Help me install a converter to HU | wsladaritz | DIY / Maintenance / Service | 8 | 09-07-2007 07:54 PM |
| Harman Kardon Drive + Play for IPOD | sroberts | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 07-01-2006 02:05 PM |
