Old 12-17-2014, 04:46 PM   #1
chancellor6869
Drives: yaris hatch is the sh*t
shifting in high rpm's
does anybody have problems shifting up or down in the higher rpm's?
even in my brand new transmission it seems like i cant drop a gear to get around someone who is driving to slow without grinding second. just wondering.....that is my only complaint about my yaris. i havent had any issues like that in my subaru or gti or any other 5 speed....
chancellor6869 is offline   Reply With Quote
Old 12-17-2014, 08:30 PM   #2
enviri
enviri's Avatar
Drives: 2010 Yaris
shifting down to 2nd is pretty awful for me too. 5-4-3 is awesome...but 2...not so much.
Old 12-17-2014, 09:15 PM   #3
roxy1
Drives: 2014 yaris 5 speed
i drop down to second at 30-50 mph occasionally. ive never had a problem with it.
roxy1 is offline   Reply With Quote
Old 12-17-2014, 10:06 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
I don't think I've ever had issues shifting down to 2nd at 50mph. But you are at a very high rpm at that speed. So you really need to rev match.
Old 12-18-2014, 04:23 AM   #5
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Yea, what IllusionX said. Rev matching will fix it.
-Derrick-
Old 12-18-2014, 10:43 AM   #6
chancellor6869
rev matching doesnt help second gear, every other gear is fine. im honestly thinking it might be that the slave cylinder. that has gone out twice already.
Old 12-18-2014, 10:51 AM   #7
nookandcrannycar
JOOC, ballpark, how many miles on the car overall?
Old 12-20-2014, 10:40 PM   #8
colj00
DIYer
Drives: yaris 1.5 MT
iv never had my yaris grind a gear, and i do track days.
except for one time when my friend got high and thought he would be helpful by putting my car in reverse for me.... without the clutch
my car is just under 60k miles.
even my corolla which is 175 000 miles and 24 years old doesn't grind gears.
colj00 is offline   Reply With Quote
Old 12-22-2014, 12:01 PM   #9
chancellor6869
my car has both a brand new motor and transmission. i figured out what was wrong....when i replaced both i left one of the subrame mounts un-torqued and it came loose so it was making a knocking sound so i got underneath there and tightened it down and when i was under there i noticed a huge puddle of gear oil sitting on the splash guard and saw that the tranny is leaking fluid so im going to break it open and re-seal it and close it back up. but for now i have topped off the fluid and driving it until this weekend for when i have time to pull it out. i think while im there im going to hand make a new splash guard because mine is all torn up and ugly.
Old 12-23-2014, 08:49 AM   #10
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Make sure the clutch is disengaging properly especially since everything is apart. Also rev matching helps.
I grind my gears everyonce in a blue moon due to a random retard moment or wet shoe
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 12-23-2014, 10:58 AM   #11
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
The only one I've ever had refuse to engage is 1st, but only if travelling over about 10 mph. I do occasionally grind 2nd or 3rd, but that's always because I mis-shift or drop the clutch too fast.
Re-sealing the gearbox is a non-trivial project. Are you sure it's between the sections and not just a shaft seal?
Old 12-23-2014, 01:01 PM   #12
chancellor6869
ya i can see exactly where the seal has worn away. i took a sos pad to it and the put son silicone there until i drop it and fix it. it fixed my issue.
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 09:49 AM
High RPM's in 3rd. Need some opinions falkor_99 General Yaris / Vitz Discussion 3 05-16-2007 08:23 PM
RPMs high when cold, not switching gears donairs DIY / Maintenance / Service 11 12-12-2006 02:43 PM
