Old 09-08-2014, 06:19 AM   #1
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
Lightbulb Inaccurate analog speedometer
Hi all.
I think many of you know that the speedometer readings in some Yaris are not accurate. I suspected this and confirmed with GPS.
I found that a speedo reading of 100kmh had actual speed of 90kmh.
I was playing around with Techstream and I ran the instrument cluster diagnostic. I found that the speedometer was infact inaccurate and even the tachometer !.
Please see these videos I made. In the second video I test the digital meter which IS accurate.
Techstream speedometer test on analog meter:
https://www.youtube.com/watch?v=5LLENLt-is4
Techstream speedometer test on digital meter:
https://www.youtube.com/watch?v=yFrP4yERDzY
I think its quite interesting.
Anyone else tried this out ?
Is there anyway to 'calibrate' the speedometer?
JudgeM is offline   Reply With Quote
Old 09-08-2014, 08:10 AM   #2
The only way I have found to calibrate them is to digitally modify the signal between the transmission and the cluster. I have only had to calibrate due to tire size differences (and only correctly 2-3 MPH at 60 MPH).
I have never seen one that far off though. I would almost suspect that the stepper motors that drives the needles are damaged from someone removing and re-installing the needle with too much force.
Old 12-23-2014, 05:00 PM   #3
Astroman
Modded Moderator
Astroman's Avatar
This was posted in the wrong section, moved it. Please remember to post your threads in the correct section.
speedometer
Analog Speedometer instead Digital Sesjusz DIY / Maintenance / Service 7 07-01-2014 11:42 AM
speedometer probs. rajjii Off-topic / Other Cars / Everything else Discussions 2 09-29-2013 10:56 AM
Tacho , Speedometer with fix on my car selimesen007 DIY / Maintenance / Service 0 07-11-2013 05:20 PM
Speedometer Calibration / DeMetrification CTScott DIY / Maintenance / Service 17 10-06-2012 09:00 PM
DEBATE: Analog vs Digital - Class D vs Old School Amps _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 64 06-09-2012 01:34 AM
