#325 |
![]() ![]() ![]() ![]() Drives: 08 BB LB Join Date: Dec 2008
Take a picture of the bottom of the lug nut, as long as the taper of the lug nut is the same as the lug seat on the wheel is the same it should be fine.
Too much of car culture is people taking things too seriously and not enjoying it for what it is. |
#326 |
![]() ![]() ![]() ![]() Drives: 2011 Toyota Yaris Join Date: Feb 2013
#327 |
Wheels are finally on! JNC 004 in polished finish, 16x8.5 +25 wrapped in 195/45s.
![]() ![]() ![]() ![]() Still have some fender work to do to minimize rubbing, go -5 in the rear with camber shims, and get shorter stiffer springs to get tighter fitment. Let me know what you guys think! Thanks everyone! Last edited by TerenceCruz; 12-29-2014 at 06:27 AM. |
#328 |
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
Omg, that's perfect, so jealous to be low.. But that's lip destroying low lol. I'm stuck with having no way to put camber in rear with my JDM axle.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
#329 |
Yeah man it's definitely a little more suspect to drive now, but it's all worth it to me haha. Once I get the fender work done and get stiffer springs, I should be solid. But thanks man! And dang, you can't put camber with a JDM axle? That's unfortunate, but at least you have rear disk brakes haha.
#330 |
![]() ![]() Drives: CS1 Join Date: Mar 2013
wow
![]() ![]() been waiting to see them on, worth the wait |
#331 |
#332 |
I also definitely want to do like a black housing in the headlights. I think it would look pretty sick.
#333 |
![]() ![]() ![]() Drives: 09 Blizzard Pearl RS LB Join Date: Sep 2009
Lookin' good bro!
Are you currently running the Megans? What spring rate are you running both front and rear? If you are still on 6kg/mm on the front, then from the looks of it you may run into rubbing issues when you turn or go over speed bumps.
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna |
#334 |
Thanks bro!! Unfortunately i am still running the 6k/3k that came with the coils. I'll be upgrading to probably 10k/8k as soon as I can. For now I have camber bolts in the front, and I can actually do a full lock. And that's with a minor roll, so hopefully it'll clear when I get a better roll job done. I'm also waiting on a reply for some -5 camber shims.
#335 |
やりすぎだ~
More pics, sir!
#336 |
Sugi where are you?! I finally have them on! Hahaha
#337 |
#338 |
More pics! The front pokes out a bit more, I don't know why. I installed camber bolts in there (one on each side) but I don't really notice the -1.5. I'll probably add one more on each side. The front passenger side is also a little higher than the front driver side. I still gotta adjust ride height and get fenders rolled before I take it to get aligned. Right now I am saving up for -5 camber shims for the rear (which will hopefully space the rear out a little more to make it even at least), as well as 10k/8K Swift springs. These 6k/3k springs aren't going to work for me for long lol. JNC center caps are on as of right now as well. Hope you guys like the pics! Sorry for the phone quality haha.
#339 |
やりすぎだ~
Nice height TC. Looks like you'll be angling over speed bumps and sweeping up leaves on your street.
#340 |
#341 |
Random phone pics, haha.
#342 |
Yep, chrome/polished wheels look best on black cars. Have you seen Martin's new wheels?
| 2010 Vitz RS Modellista Completed Car | Vitz Rs Modellista | Photo-Video-Media Gallery | 38 | 11-18-2014 01:25 PM |
| 2012 Vitz from the 2011 Tokyo Auto Salon | CTScott | Third Gen Yaris General Discussion | 14 | 02-10-2011 09:06 AM |
| Is UA-NCP13 1.5L Manual Trans a Vitz RS? | WesSunday | General Yaris / Vitz Discussion | 1 | 11-28-2010 11:47 AM |
| Newly refreshed 2011 Toyota Corolla | Kal-El | Off-topic / Other Cars / Everything else Discussions | 23 | 11-27-2010 01:57 PM |
| A German Yaris/Vitz/Echo ;) | we-to-11 | Photo-Video-Media Gallery | 5 | 06-27-2007 09:26 PM |
