Old 01-16-2015, 04:31 PM   #1
chancellor6869
Drives: yaris hatch is the sh*t
headlight help!
ok my car got backed into over the past weekend and i am just now putting it back together and now that its back together the passanger side headlight bulb is really dim and weak....i looked and noticed that some wires were exposed on the loom connected to the bumper so i cut those and re-wired with solder and wrapped up really nicely and it still didnt fix it.....its not the bulbs i checked. brand spanking new as of last night. what could it be? help!
chancellor6869 is offline   Reply With Quote
Old 01-16-2015, 07:30 PM   #2
ex-x-fire
Check the voltage & ground at the socket, if the voltage is low back probe till you find the problem.
Any pictures of the wiring?
ex-x-fire is online now   Reply With Quote
Old 01-17-2015, 02:31 PM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
you're sure the bulb is in properly?
Old 01-18-2015, 12:59 PM   #4
chancellor6869
I dont have any pics of the wiring before I soldered the cut ones....the bulb is in the right way, I even took the bulb from the other side to make sure it wasn't the bulb. I'm not very confident when it comes to wiring or any type of electrical work....so with that being said if anybody has a suggestion please explain what you mean.
Another not is I followed the wiring back and tried to find anything out of the ordinary and I couldn't......im just completely lost lol
Old 01-18-2015, 01:28 PM   #5
Get you hands on a multimeter and measure the voltage on the black wire with the headlights off (put the other meter lead on a chassis ground point).
Old 01-19-2015, 09:39 AM   #6
chancellor6869
just got to my shop and i will do this here soon. thanks. ill post back with what i find and see if i can get any suggestions on how to fix the problem.
Old 01-20-2015, 04:09 PM   #7
chancellor6869
well i feel like an idiot....i over shot the problem and didnt check what was easiest and also cheaper to replace.....it ended up being a fuse not relaying enough power. thanks everyone for the help!
Old 01-20-2015, 04:21 PM   #8
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Old 01-20-2015, 04:58 PM   #9
chancellor6869
lol exactly!!!
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 04:13 AM
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison CTScott DIY / Maintenance / Service 54 02-14-2011 08:58 AM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 02:12 AM
Glassylite Headlight Restoration Kit TEHxFALLEN V1.2 Photo-Video-Media Gallery 1 07-03-2010 12:51 AM
HELP! I detailed my interior, and now having a headlight issue! Astroman DIY / Maintenance / Service 4 06-08-2010 06:51 PM
